Just Got My 2Nd Jd317
jd317 fel
8 replies to this topic
#1 Utah Smitty OFFLINE
Utah Smitty
  • 1,701 Thanks
  • 1,781 posts
Posted July 01, 2013 - 10:33 PM
Well, I finally picked up my JD317 that I bought a few weeks ago.  I actually bought it before I got the JD420, and I bought the other 317 to have a parts tractor for this one, or whatever---use which ever one was in the best condition.
The PO swapped out the defunct KT17 and put a Kohler K321 in it.  He also scabbed together A front end loader, and chopped up the motor mounts to put the 321 in it.
He threw a rod in it, and had a mechanic replace the rod and piston... When he started it up, it started leaking oil from the block, he figured there must be a crack in the block, and decided to scrap it.
So.... I had to winch it up on my trailer.  I had bought a HF 2,000# winch.  I wasn't sure it would pull the tractor up on the trailer--the basic tractor weighs about 800#, It has rear duals with fluid in it, and the FEL, so I suspect it was about 1,200 - 1,300 lbs, and had to go up the ramp-- no ditch to put the trailer wheels into.
Surprisingly, it did just fine... it did groan a lot and slowed way down but it got up on her...
I took a short video of it with my cell phone, but I don't know how to convert it to post it here.  However, I did take a couple of pictures---
IMG_20130629_090441_073.jpg IMG_20130629_165150_054.jpg IMG_20130629_165205_991.jpg IMG_20130629_165224_639.jpg
  • JRJ said thank you
#2 Sawdust OFFLINE
Sawdust
  • 5,674 Thanks
  • 3,378 posts
Posted July 01, 2013 - 10:49 PM
One of them days your just glad to get it on the trailer. Nice looking project.
  • Utah Smitty said thank you
#3 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,773 Thanks
  • 4,265 posts
Posted July 02, 2013 - 01:28 AM
You must be a lucky guy, Smitty. Great, and w/ a FEL! Congrats!!!
#4 jdslednut OFFLINE
jdslednut
  • 679 Thanks
  • 851 posts
Posted July 02, 2013 - 02:02 AM
What size are the duals?  Might they be narrow JD rims from the early 110 era?
#5 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted July 02, 2013 - 06:56 AM
Congrats Smitty.  Seems like you have been bitten by the Green bug lately!
#6 Arti OFFLINE
Arti
  • 1,363 Thanks
  • 989 posts
Posted July 02, 2013 - 07:10 AM
With a loader it makes it worth the extra work to get it home.
#7 Utah Smitty OFFLINE
Utah Smitty
  • 1,701 Thanks
  • 1,781 posts
Posted July 02, 2013 - 08:41 AM
Yeah, I think they are... they've been painted, I plan to take them off and use regular weights or a weight box if I keep the FEL on it.
Smitty
#8 Utah Smitty OFFLINE
Utah Smitty
  • 1,701 Thanks
  • 1,781 posts
Posted July 02, 2013 - 08:48 AM
LOL!! Yeah, well I've bought things from him before... He originally wanted to sell only the tractor 'cause he wanted to use the FEL on a little Kubota he was rebuilding. I figured the bar tread tires and the extra parts he had--two more tires, front axle, steering columns, lift cylinder and valve, were worth the $300 he was asking.
Then, I got a call from him last week--his garage, with the Kubota, all his tools, welder, etc. burned down... he decided to sell the FEL as well for $300  I was a little hesitant at first as he did  very sloppy work mounting it, but, I figured I could do some plastic surgery on it, and use it on my JD420 as it has larger cylinders and a pump, separate valve, etc.
Anyway, I'll keep everyone posted... if the weather will just cool down so I can work outside without burning my hands every time I pick up a wrench.
Smitty
#9 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted July 02, 2013 - 01:58 PM
That will be a real workhorse, a 420 with a loader! Well worth the work to get it set up properly.  Weather is nutty this summer. We haven't had a sunny day for several weeks here.
Also tagged with one or more of these keywords: jd317, fel
