Need Info On Craftsman Dlt 46 Inch 25 Hp Intek.... Model Would Help ... Pics
craftsman dlt 46 inch dlt 46 inch cut craftsman dlt 46 inch
11 replies to this topic
#1 howard H OFFLINE
howard H
  • 115 Thanks
  • 108 posts
Posted June 30, 2013 - 11:58 PM
Ok, back again with a new barn find project ... today I traded 2 boxes of tomatoes from my garden for a craftsman dlt, 25hp 46 inch cut , automatic ... The serial sticker has been wiped out & I have no idea what model it is to get parts ... I think after research that it might be the dlt 3000... it has the v twin 25hp intek, automatic, 46 inch cut, green.... gas tank is right next to the serial tag under the seat & I conclude that it was in a bad place & gas got spilled over the years & wiped out the lettering on the tag... does anyone here own one or know the particular model number & year... I want to get it running as it ran great when parked... here is pictures of it... thanks
  • JRJ said thank you
#2 KennyP ONLINE
  • 38,467 Thanks
  • 45,967 posts
Posted July 01, 2013 - 12:07 AM
Not sure if it will work on this one, but I have been able to 'read' #'s by getting bright indirect light and looking at the tag where this reflects off it.
#3 howard H OFFLINE
howard H
  • 115 Thanks
  • 108 posts
Posted July 01, 2013 - 01:04 AM
It was dark & I used a flashlight but did not see anything... I will try again in the am when there is good light... seemed to be a bad place to put a sticker right next to the fuel tank cap..... we all know what gas can do ...lol... Thanks for the hint....
#4 howard H OFFLINE
howard H
  • 115 Thanks
  • 108 posts
Posted July 01, 2013 - 01:16 AM
lol... I just checked Ebay & found the exact mower & it even had the model number ... woo hoo ... might have found what I was looking for... exactly the same mower with a model number listed....
  • MH81, KennyP and Arti have said thanks
#5 timtractor OFFLINE
timtractor
  • 224 Thanks
  • 376 posts
Posted July 01, 2013 - 07:22 AM
I own one. If you are looking for belt numbers and some other info, open the hood, inside the backside of the hood there is a decal with all the part numbers for most of the items that would need replacing.
  • howard H and JRJ have said thanks
#6 howard H OFFLINE
howard H
  • 115 Thanks
  • 108 posts
Posted July 01, 2013 - 02:01 PM
I found that this morning under the hood... was dark last night when I got it home... it looked very krusty when I saw it in the light but I managed to fire it up... runs like a champ... all safety switches are functioning right, good blades, blade clutch worked fine when powered up & the trans axle is working great & no hydro problems at all ....had to weld a little on the deck as it had rusted through in a couple places... pulleys etc in great shape... need the secondary deck belt replaced & a new battery & a couple of tubes for the rear tires... washed it up with pressure washer & waxed it up good... not bad for free & cleaned up fairly well for not being taken care of much in it's life... some people just run the heck out of them & never consider maintenance... duh...lol... wonder why it was sitting in the old barn for years ...I still needed the model # since there is a couple things that require it . front deck support rods need replaced eventually getting worn out behind the clip hole etc...won't complain for free haul off & no money invested in it yet but around $150 for tubes,oil & filter/air filter, battery etc....
Edited by howard H, July 01, 2013 - 02:03 PM.
#7 timtractor OFFLINE
timtractor
  • 224 Thanks
  • 376 posts
Posted July 02, 2013 - 08:53 AM
Here are my numbers
917.272201 model number
052900A 009159 serial number
  • howard H said thank you
#8 howard H OFFLINE
howard H
  • 115 Thanks
  • 108 posts
Posted July 02, 2013 - 12:05 PM
Here are my numbers
Thanks for the numbers... they match the numbers from the one on Ebay ... has to be the model I needed... thanks again....
#9 howard H OFFLINE
howard H
  • 115 Thanks
  • 108 posts
Posted July 02, 2013 - 05:43 PM
wow, I worked on the new lawn tractor I got for free ... I never really got the chance the other night to really check it out...photos are before & after cleaning & a wax job... took no time at all to get the motor running ....puuurrrrrrrfect.... Deck needed a couple spots welded... done.... sharpened the 3 mulching blades... good condition too ... lubed it up, checked the blade clutch... worked fine.... checked the automatic trans axle... worked great with no hydro problems ...even both headlights worked! it is in good reasonable condition since I have really done no repairs on it but the welding... it looked trashed & dented in the front... still needs new battery, 2 inner tubes for the rear tires, oil & filter... ready to mow... I am always getting lucky with equipment & getting it for free or very little cash... one of my many hobbies... love fixing small engine stuff all my life...before & after cleaning & wax job pictures.............................................. GEDC2088.JPG GEDC2103.JPG
Edited by howard H, July 02, 2013 - 05:47 PM.
#10 Golden Hurricane OFFLINE
Golden Hurricane
  • 16 Thanks
  • 24 posts
Posted July 03, 2013 - 07:51 AM
HH, that looks swell. You probably made a real steal on that one! Should last a long time or you could flip it and sell it! Congrats to you!
  • MH81 and howard H have said thanks
#11 howard H OFFLINE
howard H
  • 115 Thanks
  • 108 posts
Posted July 04, 2013 - 12:24 PM
Thanks....free was a very good price... 2 boxes of tomatoes with all I got never made a dent it the harvest.... had to put $150 into it for new battery & belts, tubes oil & filters but the cash cost still was a lot cheaper than buying a mower like it.... just mowed around 3 acres with it yesterday & it never skipped a beat... fun part was making the deck adjustments to be level cut... it was way off & for a turf mower it has to be right or you leave un-level lines in the cut... it did very well....
#12 nade-em OFFLINE
nade-em
  • 202 Thanks
  • 171 posts
Posted July 05, 2013 - 08:17 PM
I'll give you 3 boxes of 'maters for it :D
Also tagged with one or more of these keywords: craftsman, dlt, 46 inch, dlt 46 inch cut, craftsman dlt 46 inch
