Fil's John Deere 420
11 replies to this topic
#1 olcowhand OFFLINE
  • 42,286 Thanks
  • 31,764 posts
Posted June 30, 2013 - 07:57 PM
My father in law's JD 420 lost a screw holding the air cleaner housing to the carb.  It got sucked into the intake & lodged under the intake valve.  I took my JD 430 to him today, then brought his 420 to my place so he could mow while I got his tractor fixed.  His air cleaner housing was also all busted up where it bolts to the carb, so I have a good used housing to replace it.  The valve & seat suffered no damage at all from the screw under the valve, as my FIL shut her down as soon as it stopped hitting on that side.
  • Texas Deere and Horse, Littledeere, New.Canadian.DB.Owner and 1 other said thanks
#2 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted June 30, 2013 - 07:59 PM
Its a good thing your father in law cut the tractor off, since a screw down in the cylinder would have really beautified his engine!
Ben W.
  • olcowhand said thank you
#3 Alc OFFLINE
  • 7,112 Thanks
  • 7,526 posts
Posted June 30, 2013 - 09:28 PM
Nice that you loaned your 430 to your fil while you fix his , do you think you'll get your 430 back  ? lol
#4 Texas Deere and Horse ONLINE
  • 14,862 Thanks
  • 15,511 posts
Posted June 30, 2013 - 09:33 PM
Boy, He sure was lucky to get it shut down before he really hurt the engine. :thumbs:  I hope you get that 430 back, he may tell you that he's happy with the even trade Y'all made. :poke:
#5 twostep OFFLINE
twostep
    Rockstar
  • 1,987 Thanks
  • 2,538 posts
Posted June 30, 2013 - 09:41 PM
Isn't what was wrong with that sunsetter that you got hogzilla's rearend out of?
#6 olcowhand OFFLINE
  • 42,286 Thanks
  • 31,764 posts
Posted June 30, 2013 - 09:56 PM
I told Teresa that was the only thing I was worried about....that he wouldn't let me have it back!  :rolling:
#7 olcowhand OFFLINE
  • 42,286 Thanks
  • 31,764 posts
Posted June 30, 2013 - 09:57 PM
Yes, and it did no damage at all to that engine either.
#8 KennyP ONLINE
  • 40,004 Thanks
  • 46,714 posts
Posted June 30, 2013 - 11:29 PM
I was worried about that 'loose screw' issue on the GTV so I made a small screen (out of metal window screen) to fit. Don't have to worry about the engine swallowing a screw now!
  • Alc and Texas Deere and Horse have said thanks
#9 Texas Deere and Horse ONLINE
  • 14,862 Thanks
  • 15,511 posts
Posted June 30, 2013 - 11:35 PM
Now that's a GREAT idea Kenny, Thanks !! :thumbs:
#10 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted July 01, 2013 - 05:20 AM
I guess those screws should be checked and some removable grade thread locker put on them. Pretty sad when a 2cent screw  lunches an expensive engine!
#11 olcowhand OFFLINE
  • 42,286 Thanks
  • 31,764 posts
Posted July 01, 2013 - 08:05 AM
I use star tooth washers and blue Loctite myself and never had an issue.  You might notice the engine has been upgraded to a 24hp Onan Performer.  Rain coming in, so may not get to put my sawdust in the stalls.  Darn, might have shop time!  :smilewink:
#12 olcowhand OFFLINE
  • 42,286 Thanks
  • 31,764 posts
Posted July 01, 2013 - 08:23 AM
Well, looks like definite shop time if it lets up enough to run down to the shop!  Pouring right now.  The red line has scooted over me since the screen shot.  Literally pouring!
