Broke A Bolt. How Deep Is The Hole?
4 replies to this topic
  • 2,331 Thanks
  • 1,498 posts
Posted June 30, 2013 - 11:23 AM
I have a 16.5 hp Briggs Twin (401707 0111 04) on a B165 Wheel Horse.  I snapped the bolt that holds the points cover on (#12-24 x ???).  I think someone used Red Loctite on it.  Now I need to drill & tap it, but how deep can I go? Also, is the hole square with the front of the engine or does it go in on an upward or downward angle?
Alternatively, how long is the bolt (minus the head) (Briggs 93854)?
  • JRJ said thank you
  • 14,800 Thanks
  • 15,495 posts
Posted June 30, 2013 - 11:38 AM
Can you weld a nut onto it? I have had great luck in doing this and the heat from the weld helps loosen up the broken bolt.
  • JDBrian, New.Canadian.DB.Owner and IlovemyCub have said thanks
#3 New.Canadian.DB.Owner OFFLINE
  • 2,331 Thanks
  • 1,498 posts
Posted June 30, 2013 - 06:41 PM
That's how the bolt got this short.  I've welded 3 nuts on to it and they have all snapped the bolt (even with the gentle back & forth trick) without loosening it at all.  The bolt was super brittle.
#4 olcowhand OFFLINE
  • 41,092 Thanks
  • 31,402 posts
Posted June 30, 2013 - 07:25 PM
I would drill no deeper than the slot between this screw boss & the push pin tower.  Place a piece of copper tubing or similar over the bit that will only allow that much bit to stick out so you can't over drill.
#5 New.Canadian.DB.Owner OFFLINE
  • 2,331 Thanks
  • 1,498 posts
Posted July 01, 2013 - 08:42 PM
Thanks for the advice.  Worked perfectly, once I got the carb & intake manifold off.  I re-sized the hole to #10 and used a #10-24 x 1" bolt.  I went to #10 because 1) I couldn't find any #12-24 bolts, 2) I had #10-24 bolts, and 3) it allowed me some room if I got the hole off centered a little.
On the up-side, the Briggs Twin lives again.  Very satisfying, hearing it come to life and run under its own power.  Runs well enough I don't think it will even need a carb cleaning, despite what the PO said in his ad.  Does smoke something fierce, but that's tomorrows problem ...
