John Deere 285 Electric Clutch
5 replies to this topic
#1 rowder OFFLINE
rowder
  • 6 Thanks
  • 15 posts
Posted June 30, 2013 - 01:29 AM
hi guys I have a question on my 285 john deere the electric clutch  the seal come off on the bearing , right under the bolt that holds it on . can that bearing be relaced has any one ever done this a new clutch is expensive , it works fine it just the seal  . id kind of like to fix it thanks guys
  • JRJ said thank you
#2 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,809 Thanks
  • 4,304 posts
Posted June 30, 2013 - 03:03 AM
First of all: welcome to gtt, rowder. :wave:
In JDPC you'll find 13 different electromagnetic pto clutches listed. Click here to find the details. I think, when your are skilled in manual work, you can chance the seal. The drawing from John Deere Parts Catalog may help you.
And, a picture of the clutch will be nice.
Edit: forgot the abridgement Attached File  John Deere 285 - Parts Catalog - e-clutch .pdf   42.15KB   370 downloads   :loosing_it:
Edited by jd.rasentrac, June 30, 2013 - 10:47 AM.
  • rowder said thank you
#3 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted June 30, 2013 - 05:54 AM
Have a look at JDParts.com and do a model search for GT285. The diagrams should show you how the clutch goes together and if JD sells the bearing alone. They are usually replaceable on the older tractors and are a standard sized bearing which is commonly available and cheap. Not sure about that on the newer GT285.
#4 Lmiller3358 ONLINE
Lmiller3358
  • 1,548 Thanks
  • 1,459 posts
Posted June 30, 2013 - 06:27 AM
I have a used electro magnetic clutch  out of a Bolen's, I have no Idea what they are worth, supposed to be good....
#5 rowder OFFLINE
rowder
  • 6 Thanks
  • 15 posts
Posted June 30, 2013 - 11:59 AM
hi guys thanks for the link but mine has a warner electric , clutch its close to the other but mine don't have the snap ring it just has a bearing pressed in the end ,then it has 3 little spots ,looks like the factory took a air chisel with a punch and just dimpled the the ouside of the pully to hold it in , but mine has a sealed bearing , the bearing is good not seemly wore just something got in there and hooked the seal, but ill have to change the bearing thanks guys
#6 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted June 30, 2013 - 03:17 PM
They can sometimes be hard to remove if you don't have access to a press. If you can find a press to use it's a whole lot easier than pounding it out.
