Innovative Aerator Adaption
aerator 3 point hitch
4 replies to this topic
#1 Utah Smitty OFFLINE
Utah Smitty
  • 1,701 Thanks
  • 1,781 posts
Posted June 29, 2013 - 11:43 PM
In the past, I would rent an aerator in the spring, and do my yard and some of the neighbors. In addition to the 80 bucks to rent it, I generally ended up with an aching back, and sore muscles.
I just bought a JD420 that came with several implements--including an aerator--my wallet and my back rejoice!!
The PO made a neat modification to the aerator.  It is a Brinley, and used to have two wheel-barrow type wheels that you pulled down, thus raising the spikes when moving.  However, it's a pain backing it up, and pulling the lever when you cross a sidewalk, etc.
His modification was to set it up for a 3 point hitch, but also to put a swivel in it so it follows the tractor around like a trailer--saves on wear and tear on the aerator.
Here are some pictures:
It works very well.  The only shortcoming is that it tends to swing to one side when it is raised, but that could be corrected by putting some stops on it--in addition to balancing out the weight on it.
FWIW,
Utah Smitty
  • Texas Deere and Horse, jd.rasentrac, Arti and 1 other said thanks
#2 KennyP OFFLINE
  • 38,337 Thanks
  • 45,913 posts
Posted June 30, 2013 - 05:01 AM
That's pretty neat!
  • larryd said thank you
#3 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted June 30, 2013 - 05:45 AM
That looks like it works really well and your back will be thanking you. Maybe a couple of extension springs or rubber hold down straps attached to either side of the aerator and attached to the hitch would provide enough of a centreing force to keep it from going sideways when raised but still allow it to pivot when turning.
  • MH81, Utah Smitty and larryd have said thanks
#4 Alc OFFLINE
  • 6,884 Thanks
  • 7,459 posts
Posted June 30, 2013 - 05:53 AM
Pretty slick set up !
#5 Utah Smitty OFFLINE
Utah Smitty
  • 1,701 Thanks
  • 1,781 posts
Posted June 30, 2013 - 10:10 AM
That's a good idea!!!  I'll have to try it.
Smitty
Also tagged with one or more of these keywords: aerator, 3 point hitch
