J D 140 H-3, Dothan, Al. $300.00 O B O
This topic has been archived. This means that you cannot reply to this topic.
7 replies to this topic
#1 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted June 29, 2013 - 03:02 PM
Not Running., with deck
http://dothan.craigs...3843455767.html
3E13K83H95La5J45Mcd6109e2f4eb50271199.jp
#2 JDBrian OFFLINE
  • 9,613 Thanks
  • 14,144 posts
Posted June 29, 2013 - 03:06 PM
Those Kolour engines are rare! Engine is black ,blue and green! Looks solid and is the newer Dana rear end which is a good thing.
#3 A.C.T. OFFLINE
A.C.T.
    Another Classic Tractor
  • 2,364 Thanks
  • 2,496 posts
Posted June 29, 2013 - 07:29 PM
Somebody is getting a great deal as seller doesn't realize what he has!
#4 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted June 29, 2013 - 08:23 PM
I don't know Brian, it looks to me like it's the old rear. Aren't the hubs recessed on the Dana's? Anyway, the tractor looks to be a 1969 model year (has the small four legged Deere recess in the headlight panel). If only I lived closer. $300.00 is very cheap for a 140, and this one looks to be complete. Somebody here needs to get this tractor!!
#5 xshooter OFFLINE
xshooter
  • 34 Thanks
  • 93 posts
Posted June 29, 2013 - 08:29 PM
It also has the older style press in dust covers on the front wheels.
#6 JDBrian OFFLINE
  • 9,613 Thanks
  • 14,144 posts
Posted June 30, 2013 - 07:16 AM
It has the wrap around U shaped rear frame that is welded to the Dana axle/rear end assembly. I think the original had a different look to the rear frame entirely. If you look at the second pic from the bottom in the ad you can see that the rear end is identical to a 314/317.
#7 twostep OFFLINE
twostep
    Rockstar
  • 1,970 Thanks
  • 2,528 posts
Posted July 02, 2013 - 10:49 AM
I believe it's the older rear. Unless you are talking about something else, mine has that same bracket on the rear. Plus if you look closely to the bottom side of the left axle tube, there is a small step down which also matches mine.
Mine has yellow dust caps over the ends of the rear axle (center of hub).
#8 twostep OFFLINE
twostep
    Rockstar
  • 1,970 Thanks
  • 2,528 posts
Posted July 02, 2013 - 11:03 AM
Does the Dana rear have the travel/tow valve in the same spot?
