Mounting A Bucket To My Cub Cadet 129
10 replies to this topic
#1 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,026 Thanks
  • 3,172 posts
Posted June 29, 2013 - 09:52 AM
This is something I started a couple of years ago, and I have changed my mine a few times on this but here is the 1st video I did of it.
  • wvbuzzmaster, KennyP, dropped82 and 1 other said thanks
#2 Amigatec OFFLINE
Amigatec
  • 2,026 Thanks
  • 3,172 posts
Posted June 29, 2013 - 11:36 AM
  • Alc, wvbuzzmaster and KennyP have said thanks
#3 bgkid2966 OFFLINE
bgkid2966
  • 1,412 Thanks
  • 1,331 posts
Posted June 29, 2013 - 11:59 AM
I have an electric winch mounted on my 129 for raising my snow plow. Here are some pictures.
Hope fully these will give you some ideas.
Geno
#4 Amigatec OFFLINE
Amigatec
  • 2,026 Thanks
  • 3,172 posts
Posted June 29, 2013 - 12:02 PM
I hadn't thought about bolting something under the grill, I may have to look into that.
#5 Amigatec OFFLINE
Amigatec
  • 2,026 Thanks
  • 3,172 posts
Posted June 29, 2013 - 06:03 PM
I think I have figured out a way to mount the winch, the frame already has numerous holes drilled in it, so I don't feel bad about drilling more. But I think I can come along the side below the grill with some angle iron. Come up the front to about the hood, and mount the winch in front. I will have to add some bracing.
#6 dropped82 OFFLINE
dropped82
    Nut Case
  • 2,740 Thanks
  • 1,905 posts
Posted June 30, 2013 - 08:21 PM
I'm tagging along on this. I've thought of doing something similar on my Case 446. Except I was gonna use the factory lift similar to what the blade uses and running another hydro spool for the dumping action. I tthought the Swisher bucket would be a shoe-in.
Eric
Sent from my XT897 using TapataIk 2
Edited by dropped82, June 30, 2013 - 08:25 PM.
#7 Amigatec OFFLINE
Amigatec
  • 2,026 Thanks
  • 3,172 posts
Posted July 01, 2013 - 02:56 AM
I'm also going to have to rework the mounts some, I have a couple of ideas. I need a piece of metal across the front, and I'm going to have to build a saddle for the back.
#8 TAHOE OFFLINE
TAHOE
  • 8,309 Thanks
  • 5,803 posts
Posted July 01, 2013 - 08:09 AM
My bucket sits out pretty far, but I wanted it like that so I could get max lift on it. I sometimes put a 55 gal drum up on the tail of my trailer using bucket so I needed height. It does affect lift capacity, but I can still lift 350# in the bucket before my butt end starts getting air under tires, i could use more counter weight. Looks like the swisher bucket has more weight just in it than mine so that would even be more of an issue with yours.
#9 Amigatec OFFLINE
Amigatec
  • 2,026 Thanks
  • 3,172 posts
Posted July 01, 2013 - 09:27 AM
I am working on a way, so I can just pin and unpin it from the tractor. The mount is in the very early stages now.
The bucket really isn't that heavy, I can pick it up and carry it for short distances.
Edited by Amigatec, July 01, 2013 - 09:28 AM.
  • wvbuzzmaster said thank you
#10 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted August 05, 2016 - 10:21 PM
Any progress on this project or did you can it?
I am about to buy a Swisher bucket to throw on my New Holland S14, and trying to determine how crazy I am based on others' success stories. So far my research is missing some information, such as successful completions by others of similar thought processes. If you need more ideas to jump start this project again, let me know, I have some ideas already.
  • KennyP and Paulgo have said thanks
#11 KennyP ONLINE
  • 40,925 Thanks
  • 47,121 posts
Posted August 06, 2016 - 03:55 AM
OP has been on for a year!
