Farmall F-20 Tractor, Head Torque
farmall f-20 head torque
4 replies to this topic
#1 boyscout862 OFFLINE
  • 13,552 Thanks
  • 9,427 posts
Posted June 28, 2013 - 05:44 PM
A friend is working on a 1937 Farmall F-20. He can't find the head bolt torquing sequence nor required torque. His manual doesn't have it. He was handing out fliers, looking for the info, at the truck show last weekend.
I have not been able to find the info either. Anybody here know where I should look? Thanks, Rick
Edited by boyscout862, June 28, 2013 - 05:46 PM.
#2 IlovemyCub OFFLINE
IlovemyCub
  • 172 Thanks
  • 204 posts
Posted June 28, 2013 - 05:46 PM
http://www.yesterday...ll&th=347235%3E
I think this should help. Ian
  • MH81 and boyscout862 have said thanks
#3 olcowhand OFFLINE
  • 42,898 Thanks
  • 31,941 posts
Posted June 28, 2013 - 05:50 PM
All references I can find say 85 to 90 foot pounds.  Here is what one guy stated, and it's the way I do heads also.
Go in steps like 20,40,60,80, then 90 and work from the center out and from side to side for each step or the head gasket will be damaged.
#4 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted June 28, 2013 - 06:30 PM
Daniel is right, 85-90 is what I do.  As long as your spread out the tightening (like a lug on a tire) then your friend won't have any trouble.
Ben W.
#5 boyscout862 OFFLINE
  • 13,552 Thanks
  • 9,427 posts
Posted June 29, 2013 - 06:10 AM
I gave Jon the info. He is still in the vacuum tube era as far as technology so, was surprised at the speed of getting info. He says thanks. I'll let you guys know how it goes when he gets it back together. Good Luck, Rick
