Running Tractor! I Rode It Naked!
11 replies to this topic
#1 glgrumpy OFFLINE
  • 8,605 Thanks
  • 7,909 posts
Posted June 27, 2013 - 05:55 PM
Nope! no pictures....heh!   Really the Tractor was Naked, not Me!  1430 running great, starts right up with electric start now. Trans works and the belt tensioner/engine slider seems to be just fine now with little longer belt on it. Painted some tin today, will be adding those this week-end. I'll try to get some more progress pictures. I just idled around in each gear as no throttle cable on it yet.
Could use some help with pix of YOUR models with way choke and throttle cables are run. I have a metal support for one, don't recall where it goes, and both seem way short!  Hmmm, maybe I should take pix when I tear down, don't seem to recall the "how" as well in my old age.
  • Dieselcubmike said thank you
#2 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted June 27, 2013 - 06:06 PM
Gettin' old sux!
#3 pharmer OFFLINE
pharmer
  • 871 Thanks
  • 774 posts
Posted June 27, 2013 - 06:23 PM
When I read the title I was about poke my brains eye out. Glad I read the text.
#4 KC9KAS OFFLINE
KC9KAS
  • 5,383 Thanks
  • 4,690 posts
Posted June 27, 2013 - 06:35 PM
After reading the title, I was afraid to open the thread! :poke:
#5 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted June 27, 2013 - 06:58 PM
I guess George edited out the pictures, otherwise that would have been a bit chaotic.
I'm glad you got it running, just don't embarrass it so much next time.
Ben W.
#6 OkieGt OFFLINE
OkieGt
  • 1,428 Thanks
  • 1,447 posts
Posted June 28, 2013 - 12:33 AM
Doesn't everybody ride their tractor naked once in a while, even if it's only under the light of a full moon at full throttle
#7 MH81 OFFLINE
Posted June 28, 2013 - 07:05 AM
  • KennyP and backwoods have said thanks
#8 jimbobbillyray OFFLINE
jimbobbillyray
  • 2,822 Thanks
  • 2,781 posts
Posted June 28, 2013 - 07:40 AM
They called him the streak?  WAY back when I was 14 and working at the local Dairy Queen one night, a girl came running in one door and ran thru and out the other door.  She waved at us and the other customers as she went by.  she wasn't completely naked, she had on a pair of tennis shoes.  Yes, that was nearly 40 years ago.......
#9 glgrumpy OFFLINE
  • 8,605 Thanks
  • 7,909 posts
Posted June 29, 2013 - 10:02 PM
Worked all day on this thing and looking pretty good. Only the Hood is needing work now. I DID separate the grill section from the hood by cutting/grinding some ugly welds someone made where it must have split apart before. I could then get it into my blaster, just barely. I'm going to have couple angles bent up from tin and bolt it all on again, so can be taken apart if needed in future. Have the fenders all on, the dash is done and installed with switches in place. Throttle and choke working. Put in the light switch, but no lights on it yet. Gonna try to put them in the rear fenders on front, like MM's and Olivers used to have. I found that white wire out of housing was for lights, hooked one up and it works!  So there is power source for them. the other terminal there is for charging battery, but needs the wire coming out of the cap. There is a diode I think in the holder.  Found info in the BS manual on that.
#10 LilysDad OFFLINE
LilysDad
    Millennium Falcon
  • 13,282 Thanks
  • 9,771 posts
Posted June 30, 2013 - 07:30 AM
Watch out for mufflers!!!
#11 MH81 OFFLINE
Posted June 30, 2013 - 07:56 AM
Or missing belt guards. ;)
#12 glgrumpy OFFLINE
  • 8,605 Thanks
  • 7,909 posts
Posted June 30, 2013 - 12:51 PM
OK! Can we KILL the Naked parts here. Sheesh! Trying to make updates, but guess I should start another posting maybe. Everyone trying to be funny!  (gee, what did I start here?)
