So the piston is .030" oversize.. The old rod will work as long as the rod-to-crank clearance is OK and isn't out of tolerance.. Get some plasti-gauge to check.. If the crank is machined down the rod is smaller (ie- .030" under)
If you are spending the money on a new piston, new rings, and the boring as well as all the other things you should do to make sure the engine's last leg of life is good, don't skimp by forgetting to replace the rod. It shouldn't be that expensive, and you will have peace of mind.
Any cast iron Kohler is worth it. Do you have to go.030 over? Measure it first . Going .030 over is not going to gain HP. Besides, kits on Ebay are around $90 and includes the rod for .010 or .20 over. .030 over adds another $20. Measure first, bore and crank and go from there.
Head work,porting, 3 angle valve job, and flowing the carb better is what can be done to these great engines. Visit Brian Millers page if you haven't done so yet.
Related Threads
Garden Tractor Forums
951.2K posts
49.2K members
Since 2010
