Eaton 11 - Need Help Where To Get Spare Parts.
eaton
12 replies to this topic
#1 Per OFFLINE
Per
  • 144 Thanks
  • 121 posts
Posted June 27, 2013 - 09:26 AM
Hi,
I have a problem and I need some help.
I have noticed that the input shaft on my Eaton 11 is bent and going a lot up and down when it turn. Does anyone know where I can buy a input shaft for this Eaton 11.
This is a Picture of the Eaton 11.
The number on the Eaton 11 is:
1100 014
A15J CCW
It is the input shaft pos #21 I am asking about.
Also there is no cooling fan. Is it necessary to have this?
I don't think I can get parts here in Denmark but maybe there is a dealer in U.S. A. who will ship to Denmark. Can somebody help me?
#2 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted June 27, 2013 - 10:54 AM
OUCH!!! Your best bet would be to find one out of a used unit . I see them on Ebay all the time. Are you sure it'sthe shaft and not just the coupling flange ?
  • Per said thank you
#3 boyscout862 ONLINE
  • 13,555 Thanks
  • 9,430 posts
Posted June 27, 2013 - 10:56 AM
Try our sponsors too. Good Luck, Rick
#4 Per OFFLINE
Per
  • 144 Thanks
  • 121 posts
Posted June 27, 2013 - 12:58 PM
Yes I am 110% sure it is the shaft. I have had the coupling flange disconnected and it is quite easy to see that the end of the shaft is bent. The end is going up and down.
I am thinking of dismantling the hydrostate and take it apart in order to get the shaft out to line it up, but I would like to have one in spare before I do anything. I am having quite some problems to loosen the two set screws holding the coupling on the shaft. Maybe I have to cut of the shaft so I can warm the coupling up. Therefore I would like to have a spare shaft.
#5 Per OFFLINE
Per
  • 144 Thanks
  • 121 posts
Posted June 27, 2013 - 01:02 PM
Is there any of them you can recommend?
I don't know any of them.
#6 wilberj OFFLINE
wilberj
  • 5,097 Thanks
  • 5,625 posts
Posted June 27, 2013 - 05:16 PM
Its not a shaft its called a rotor its more then a shaft when you bust it down you'll see. I Would go with Bob First. http://gardentractor...arden-tractors/
I have had a rotor fixed in a eaton 12 the bent end was terned off, then a hole was drilled into the rotor were the saft was. A new shaft was pressed in the hole then welded and terned. The shaft you see is casted into the rotor so its all one part.
#7 Per OFFLINE
Per
  • 144 Thanks
  • 121 posts
Posted June 29, 2013 - 06:21 PM
I don't understand that. The drawing show clearly, that it is a shaft with a cross pin at one end which drives the pump rotor.
I have made contact to Bob and he wrote back, that he would check for a shaft, but I've not heard from him yet.
#8 wilberj OFFLINE
wilberj
  • 5,097 Thanks
  • 5,625 posts
Posted June 30, 2013 - 12:28 AM
Ok I looked a the pics you posted I never been into a Eaton 11 I was thinking it was like others like the Eaton 12 with every thing casted togather but I see its not the same now!
#9 Per OFFLINE
Per
  • 144 Thanks
  • 121 posts
Posted July 02, 2013 - 04:54 PM
Is there a list where you can see which GT use a Eaton 11 running CCW?
Does anyone know?
#10 Per OFFLINE
Per
  • 144 Thanks
  • 121 posts
Posted July 02, 2013 - 05:22 PM
Can somebody confirm that this Eaton is running CCW?
http://www.ebay.de/i...10221992&_rdc=1
#11 olcowhand ONLINE
  • 42,898 Thanks
  • 31,941 posts
Posted July 02, 2013 - 06:14 PM
This one DOES turn CCW as viewed from the input end of the hydro unit.  It connects the the flywheel side of the Kohler engine.
#12 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted July 03, 2013 - 03:31 AM
It doesn't matter if all you want is parts from it.
If you have a newer Eaton 11 I would use just the shaft from an older one, you never know what could be wrong with it ,and the older units from Ford/Jacobsen anyways, don't have cushion valves . Not really an issue, but if your tractor is run by a hand lever instead of a foot control you may not like the jerkyness . I have been into these units and they are very simple BUT, BUT BE CARFULL You don't want to mix any of the  rollers up in the charge pump or any of the balls in the main pump SO BE CAREFULL !  :(  :thumbs:
#13 Per OFFLINE
Per
  • 144 Thanks
  • 121 posts
Posted July 14, 2013 - 01:49 PM
Yesterday I got a shaft from Bob. He has given me a great service.
But I now ran into some other problems :wallbanging:  :mad2:  :wallbanging:  :mad2:  :wallbanging:  :mad2:
Also tagged with one or more of these keywords: eaton
