Good Gas
30 replies to this topic
#16 poncho62 ONLINE
poncho62
  • 2,116 Thanks
  • 1,784 posts
Posted June 26, 2013 - 05:18 AM
My Kohlers will run on gas that was sitting in it from last year, so I cant see it being that.....but who knows.
Sounds to me that its still not getting gas, since it fires when you spray it in
  • DH1 said thank you
#17 Alc ONLINE
  • 7,229 Thanks
  • 7,580 posts
Posted June 26, 2013 - 06:02 AM
Is there any way to see if it's pulling enough vacuum to pull fuel/air into the motor ? Maybe a peice of paper across the carb ?  If it was a automotive engine I would find a vacuum point to attche a gauge to .not sure on a small engine
#18 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted June 26, 2013 - 06:16 AM
Sounds like a stuck float or blocked fuel inlet, sticking needle.
#19 Lmiller3358 OFFLINE
Lmiller3358
  • 1,547 Thanks
  • 1,458 posts
Posted June 26, 2013 - 06:36 AM
It seems it may be flooding, My 12 hp Kohler is the peskiest thing I have to start, DH1, when you get it cranking over, pull the governor open and see it starts then, I have to do that quite a bit !
#20 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted June 26, 2013 - 07:31 AM
If it won't run with other good carbs on it , I think you have a valve issue ,its not making vacuum to draw in the fuel. If you force it by spraying it in, it runs. Check your valve clearances and also your crankcase venting. If its plugged it may do the same thing.
  • DH1 and Texas Deere and Horse have said thanks
#21 Canawler ONLINE
Canawler
  • 1,951 Thanks
  • 1,806 posts
Posted June 26, 2013 - 10:35 AM
You did open the inline fuel shut off valve, right???  :D
#22 Cvans ONLINE
  • 7,289 Thanks
  • 6,379 posts
Posted June 26, 2013 - 02:10 PM
Are you sure your ignition timing is correct. Many will tell you that if you have fuel, compression, and ignition that a motor has to run. That is only partially true. These things need to come together at the correct time. Timing chain or gears that are out of time can create a world of problems.
#23 HydroHarold OFFLINE
HydroHarold
  • 703 Thanks
  • 977 posts
Posted June 26, 2013 - 07:33 PM
I'll add my little toot to this gas issue...  You CAN get bad gas!  Even from a busy station, I got bad gas, a lot of it!  Several years ago I filled 3 5gal. cans from my local Momar Mart and everything came to a spitting, coughing halt.  WATER, plus a bunch of nasty foreign objects floating and sinking in all three cans.  LSS, the filler and vent pipes on the dealer's tank were broken at the cap threads and allowing water to enter.  I brought the glass jars of "proof" down there and he had the tanks checked... then changed out.  He actually thanked me.
Remember the old adage, "Don't buy gas when you see the tanker delivering!"?  It's just as true today if there's foreign matter in those tanks.  It roils around pretty good in there for a while after the tanker leaves and goes right into the pump pickup pipe...
Not saying this is the OP's problem, that can be tested with new gas from a car that's running OK or another station, but I still go back home and wait a day if I see the delivery going on.
#24 DH1 ONLINE
DH1
    Electric Tractors
  • 5,422 Thanks
  • 5,617 posts
Posted June 26, 2013 - 10:15 PM
It runs
I pulled the fuel tank flushed it out with some fresh gas and the fuel lines, filter, pump. Pulled the carb apart cleaned it out real good, did this to 2 carbs.
Put it all back together with some new today gas and no luck. ????
Changed the coil and it fired right up, still doesn't want to run smooth at a fast speed.
Going to try a new condenser I don't have a new or know good one so tomorrow I nave try to find a new one somewhere.
All this fuss for a bad spark, funny the spark shows at cranking speed with the plug out, but in the cylinder I guess it doesn't want to fire.
Learn  something new everyday.
Edited by DH1, June 26, 2013 - 10:16 PM.
  • MH81, Alc, Texas Deere and Horse and 1 other said thanks
#25 Texas Deere and Horse OFFLINE
  • 14,889 Thanks
  • 15,514 posts
Posted June 26, 2013 - 10:35 PM
Glad you got it figured out Doug. sometimes the problem can hide itself very well.
#26 IamSherwood OFFLINE
  • 8,395 Thanks
Posted June 26, 2013 - 10:47 PM
Victory!
Good to hear.
Banta has the condensers. You might want to change the points, while you're at it.
#27 Cvans ONLINE
  • 7,289 Thanks
  • 6,379 posts
Posted June 26, 2013 - 11:28 PM
I'm going through the same thing with an old Briggs right now. The guy was using ethanol in it and I have never seen so much water and corrosion in a system. I just overhauled the carb last summer and you would never know it. Now it starts right up but the spark is very erratic. Points are good and when I turn the flywheel by hand it gives me a good jolt. Condenser is next. Hope it works.
Edited by Cvans, June 26, 2013 - 11:29 PM.
#28 bigcountry48 OFFLINE
bigcountry48
  • 101 Thanks
  • 207 posts
Posted June 27, 2013 - 12:32 AM
I have a spark checker I got from harbor freight, and boy does that thing save me trouble. You don't have to do anything but hook the wire to it and see if you have fire. It's a lot easier than touching the spark plug to the block and looking for a tiny spark or shocking yourself!
Edited by bigcountry48, June 27, 2013 - 12:37 AM.
#29 Utah Smitty ONLINE
Utah Smitty
  • 1,710 Thanks
  • 1,793 posts
Posted June 27, 2013 - 05:03 PM
It runs
I've heard that some plugs are defective such that they will fire fine out of the engine, but won't fire under compression... FWIW.
The condensor for those are a normal (well at least normal for when I was a teenager) automotive item.  Check your points also... they might need to be filed or replaced.
Smitty
#30 MH81 OFFLINE
  • 29,979 Thanks
Posted June 27, 2013 - 05:20 PM
It runs
Doug, I've had that with Champion plugs several times.
