1965 Case 130
26 replies to this topic
#16 IlovemyCub OFFLINE
IlovemyCub
  • 172 Thanks
  • 204 posts
Posted June 26, 2013 - 07:38 AM
Nice find! Thanks for sharing! Ian
  • Jlaws said thank you
#17 Jlaws OFFLINE
Jlaws
  • 554 Thanks
  • 368 posts
Posted June 26, 2013 - 10:40 AM
Thanks guys ,
A friend who happens to have a 1966 Case 150 told me how it was a rarer more desireable tractor it was when I got it . Also told me if I decided to sell it to let him know . I once owned a 220 Case which my son borrowed about 10 yrs ago and still has , so I know how tough they are .
I'll  probably just chean it up a bit and leave it in the faded  original paint since it seems to be in mostly unmolested original condition .
Old abe is on the front , but the hood latch seems to be MIA with a small hole where it used to be .
I'd be interested in pictures of what the mower deck looked like , if anyone has any ,  in case I stumble across one in the future .
#18 Jlaws OFFLINE
Jlaws
  • 554 Thanks
  • 368 posts
Posted July 06, 2013 - 09:11 PM
pics
  • bigspoon said thank you
#19 abushey123 OFFLINE
abushey123
  • 13 Thanks
  • 45 posts
Posted July 09, 2013 - 10:02 PM
Great tractor! Congrats! That would make an awesome restoration project, or just leave it original!
However, how did you come up with 1965 for the year? They where only made in '67 and '68.
I beleave they were only made in the year 1965
  • Mjoe7 said thank you
#20 Mjoe7 OFFLINE
Mjoe7
  • 173 Thanks
  • 172 posts
Posted July 10, 2013 - 01:27 AM
I believe they were only made in the year 1965
That is correct! 65 only!
Edited by Mjoe7, July 10, 2013 - 01:28 AM.
#21 190forklift OFFLINE
190forklift
  • 37 Thanks
  • 31 posts
Posted July 11, 2013 - 06:19 PM
And in 1965 there were 5 colt models Deluxe,super10 ,super H, Rancher 10, Rancher 12. Steve
#22 Jlaws OFFLINE
Jlaws
  • 554 Thanks
  • 368 posts
Posted July 18, 2013 - 05:05 PM
OK , I've got a question about the Case hydraulic drive system used on my case 130 .
I know its only has a 10 hp kohler but the hydraulic drive system seems to draw a lot of power when put under a load .
I was out with the 130 today stirring my compost pile with the 42" snowblade and noticed that it seemed harder for the 130 than I usually experience with my cub 100  . I usually use my 10 hp kohler 100 cub which is a gear drive and also has a 42" snowblade . I know it isn't really fair comparing a hydro to a gear drive  .
I once owned a 10 hp  Case 220 with a 48" mower deck that came off a 400 series Case and i noticed that it would mow fine till I started up a hill . That's when I noticed that the drive system seemed to draw more horsepower than the oversized deck did ?
I've seen some of the 400 series Case's at plowdays and they seem to do fine , so I'm wondering if its just a problem with the 130 only being 10 hp or do I have a possible problem with the hydraulic drive system ?
I guess what I'm asking ? Is the Case hydraulic drive system as efficient as the Cub hydrostatic system ?
I'm not knocking Case , and I do like my 130 but ,
My first impression is that it isn't .
#23 dropped82 OFFLINE
dropped82
    Nut Case
  • 2,501 Thanks
  • 1,818 posts
Posted August 06, 2013 - 10:18 PM
From what I've read the Case system is not nearly as efficient. Also from my experience the Case system will draw up to 12hp. Anything over that goes to the PTO. So with only 10hp and the large deck, I can see why your losing speed and power. The 10hp is not enough to maximize the potential, meaning the hydro system has more capacity than the engine can put out. That also means there is nothing left for the PTO. In the sales manuals I have, Case recommends the 38" deck for the lower HP tractors. Now that is for the 200 series but I would imagine the same applies to the 130.
Eric
Sent from my XT897 using Tapatalk 2
#24 Mjoe7 OFFLINE
Mjoe7
  • 173 Thanks
  • 172 posts
Posted August 07, 2013 - 01:55 AM
There are good things about the CASE hydriv system. The most obvious is one pump does it all. Making attachment hookup one of the easiest there is. Time yourself hooking a tiller up to a 125 Cub vs. a CASE and you'll have the garden done with the CASE before the Cub tiller is mounted.
I think it saves wear on the engine since you usually have more power than what the pump can deliver for pulling so it's easier on it.
I like having an oil only link between engine and trans. It saves wear and tear and cushions sudden jolts or stops that would otherwise break something.
A good Hydrostatic is probably better to some degree, but that could go both ways. Both have pressure relief valves so your limited on both anyway.
The CASE system doesn't whine like some hydro's do. I find it annoying.
A 48" deck does not belong on a 10 hp GT. I don't care what system you have driving the wheels it will lack in power greatly even with a strong 10 hp engine.
Lastly a 130 is very old and not built near as good as a 400 or 200 series. Its good, but it just wont compare to a 226 Onan powered CASE GT. It's likely that most everything is worn out to a certain degree from when it was new so it will not function as well as it once did.
My thoughts anyway.  :wave:
  • dropped82 said thank you
#25 jessie OFFLINE
jessie
  • 11 Thanks
  • 14 posts
Posted July 02, 2015 - 11:27 AM
Just finished a Case 130.Still looking for small tool box behind seat!!!
  • Mjoe7 and cmn135 have said thanks
#26 190forklift OFFLINE
190forklift
  • 37 Thanks
  • 31 posts
Posted September 15, 2015 - 12:58 PM
They still made 3 colt models in 65  with the 130 & 180 .
They made 5 models in 65. Colt Rancher 12, Rancher 10, Super H, Super 10, Deluxe  10. Plus the 130 and 180 case. Steve
#27 Talntedmrgreen OFFLINE
  • 3,273 Thanks
  • 2,306 posts
Posted September 16, 2015 - 07:20 AM
In 1967 Case dropped the Colt line.
Case acquired Colt in 1965 and they made both lines of GT's next to each other. The Case had a Kohler engine the Colt had a Tecumseh.
I thought Colt went to Kohler power in all tractors for '65?  ...then back to Tec in the Colts only for '66 when they did the redesign?
