Bolens "husky 800"
95 replies to this topic
#61 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted September 15, 2013 - 07:50 AM
I think the easiest thing to do is keep the old wiring thats there and use it as just a starter to get the tractor turning over. The On/Off of the coil will be on a separate system with just a simple on/off toggle switch.
All you need to do is install the coil somewhere on the tractor and install wire from the points to the negative side of the coil (Black wire) and the other wire (Positive side of coil) will go to the one terminal on the switch. (White) The other wire will need to be attached to the positive terminal of the battery (Red)
#62 woopud OFFLINE
woopud
  • 74 Thanks
  • 167 posts
Posted September 15, 2013 - 08:06 AM
So, could I just use the parts (NAPA 7-01634 and 7-01338) and which coil do I need?  Also, will these points fit in the original "box"?
Thanks,
Bert
#63 woopud OFFLINE
woopud
  • 74 Thanks
  • 167 posts
Posted September 21, 2013 - 07:23 PM
Can anyone tell me exactly which points, condenser and coil will work for this conversion?
#64 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted September 21, 2013 - 07:28 PM
You will Need a YQ11 points kit  Its your lucky day, there's a couple on ebay for a steal!
http://www.ebay.com/...006a3d2&vxp=mtr
Any 12volt automotive style coil will work. Just make sure its the one with an internal resistor.
#65 woopud OFFLINE
woopud
  • 74 Thanks
  • 167 posts
Posted September 22, 2013 - 10:31 AM
Well, I finally managed to get the flywheel off thanks to krsword!  The magneto looks fine but is there a way to test it?
#66 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted September 22, 2013 - 04:50 PM
Did you check the wires? Looks like that one was taped a few times and may have a short. How strong are the magnets on the flywheel?
#67 woopud OFFLINE
woopud
  • 74 Thanks
  • 167 posts
Posted September 22, 2013 - 07:11 PM
If I fix that wire can I still test it with a sparkplug connected to the plugwire while cranking the engine?
#68 woopud OFFLINE
woopud
  • 74 Thanks
  • 167 posts
Posted September 23, 2013 - 08:10 PM
So, I'm still trying to figure out the battery ignition option. If I get a regular coil, can I still use the original points and condenser set? Or do I need different points and do they go in the original box?
#69 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted September 23, 2013 - 08:27 PM
The OEM YQ11 Points and condensor can be used with a battery ignition system.
I think your looking too far into this, its really quite a simple procedure to get a coil installed on these.
  • woopud said thank you
#70 woopud OFFLINE
woopud
  • 74 Thanks
  • 167 posts
Posted September 24, 2013 - 05:38 AM
Thanks Bolens 1000,
I thought I needed a different points and condenser setup if I'dd go with a regular coil.  Getting a new point and condenser, install them in their original location and then instead of the wire going to the magneto it will just go to the external mounted automotive coil which will have a separate on/off switch somewhere correct?
#71 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted September 24, 2013 - 07:19 AM
Thanks Bolens 1000,
Yes, That is correct.
#72 woopud OFFLINE
woopud
  • 74 Thanks
  • 167 posts
Posted September 24, 2013 - 06:14 PM
Thank you again! Now I'm finally on the right track.
#73 EricFromPa ONLINE
EricFromPa
    Fixer of Broken junk
  • 6890 Thanks
  • 4615 posts
Posted September 26, 2013 - 02:57 PM
Here's a very simple wiring schematic.
  • Bolens 1000 and Newpaws493 have said thanks
#74 woopud OFFLINE
woopud
  • 74 Thanks
  • 167 posts
Posted September 26, 2013 - 07:14 PM
Thanks guy's, I got the points set on EBay once they come in I'll test them with the original magneto, if there's no spark I'll just stop at advance Auto parts and pick up a coil.
#75 woopud OFFLINE
woopud
  • 74 Thanks
  • 167 posts
Posted November 13, 2013 - 07:10 AM
Finally had some time to play with the Husky, I have a spark!  Found a nice start push button at Advance Autoparts and wired it in.  Next step is cleaning the carb, will keep you posted.  Anyone knows what kind of connectors I need for the coil?
