Any members on here have a starter button he wants to sell me?
Bolens "husky 800"
#46
OFFLINE
Posted August 18, 2013 - 06:51 AM
#47
OFFLINE
Posted August 18, 2013 - 10:19 AM
Just spend about an hour playing with the Husky and got the ignition key switch and starter relay figured out, I can now turn on the ignition and crank the engine. Next step is the ignition itself to get a spark, also...the Amp meter, does that have a + and - or doesn't it matter how you wire it?
- Newpaws493 said thank you
#48
OFFLINE
Posted August 18, 2013 - 12:22 PM
Keep at it, take your time and study up...looking forward to the progress reports
http://gardentractor...anual-552875-1/
http://gardentractor...-owners-manual/
- chainsawchips said thank you
#49
OFFLINE
Posted August 19, 2013 - 06:57 AM
Can anyone show me a drawing of a simplified wiring layout from the wire that comes from behind the flywheel?
#50
OFFLINE
Posted August 23, 2013 - 10:24 PM
Still trying to figure out the ignition wiring, I can turn on the ignition and crank the engine with the keyed ignition/starter switch but now I'm trying to figure out the rest of the wiring. As seen in the picture....where does the red wire hook up to?
#51
OFFLINE
Posted August 24, 2013 - 07:20 AM
On the old system I believe that one red wire went to the single post on/off switch and its purpose was to just ground out the engine.
With magneto ignition, getting spark has nothing to do with the Voltage reg, Solenoid, battery or ammeter. Those are all for the starter generator.
To test for spark before you go any further with the old cobbled wiring, disconnect that red lead to the points box (not the one that goes to the magneto behind the flywheel), remove the starter belt and use a pull rope to manually crank the engine. You should be getting spark
#52
OFFLINE
Posted August 24, 2013 - 07:49 AM
Well, I do not have a spark (new plug). Looks like I'm gonna have to take off the flywheel anyway...
#53
OFFLINE
Posted August 24, 2013 - 09:17 AM
Did you clean/ Gap your points?
#54
OFFLINE
Posted August 25, 2013 - 07:18 PM
Any updates?
The points are right in that box and usually just need a good cleaning.
#55
OFFLINE
#56
OFFLINE
Posted August 26, 2013 - 05:54 AM
Someone tried to explain to me how to test for a spark by connecting a ground wire where the points connect to to see if my coil is still okay but haven't figured that out yet.
#57
OFFLINE
Posted August 26, 2013 - 06:13 AM
Wow,
I dont think I've ever seen points burn completely off like that!
I'm guessing this occurred when the previous owner attempted to re-wire the ignition. Even looks to be burned near the mounting bolt.
Hopefully he didnt screw up your magneto.....
The points set is Wisconsin # YQ11
I would get the points replaced then test again for spark. If the mag is bad the easiest thing would be to get a 12vt coil installed.
- Bruce Dorsi said thank you
#58
OFFLINE
Posted August 26, 2013 - 09:19 AM
The only possible way I can see the points melting like that is if someone put 12 volts to the points, while they were closed.
This would be a direct short to ground, and with the high amperage available from the battery, the point arm would act like a fuse and burn through.
Sadly, 12 volts would have also flowed through the primary circuit of the magneto coil, and that probably got fried as well.
Most likely the cause was improper wiring, or the wrong ignition switch.
- Bolens 1000 and Newpaws493 have said thanks
#59
OFFLINE
Posted August 26, 2013 - 07:39 PM
Yes, thats what I was thinking
Judging by the wiring job in the pictures I dont think the previous owner really had any idea what he was doing.
#60
OFFLINE
Posted September 15, 2013 - 06:58 AM
Wow,
Could you explain to me how to set up a automotive ignition coil?
