Bolens "husky 800"
#31
OFFLINE
Posted July 08, 2013 - 05:08 PM
#32
ONLINE
Posted July 08, 2013 - 05:24 PM
If the previous owner kept the new wiring to specs you wont need a battery to start the tractor if you just want to see if it runs before buying a battery.
Its Magneto powered so all you have to do is remove the starter belt and just pull start it.
#33
OFFLINE
Posted July 08, 2013 - 05:35 PM
#34
ONLINE
#35
OFFLINE
Posted July 08, 2013 - 06:02 PM
#36
ONLINE
#37
OFFLINE
Posted July 08, 2013 - 08:25 PM
Do you have a puller?
I got the nut off, what kind of puller do I need?
#38
OFFLINE
Posted July 11, 2013 - 06:51 AM
Can anyone tell me where the ground cable is supposed to be mounted on the frame? It was missing when I got the Husky.
#39
OFFLINE
Posted July 11, 2013 - 05:30 PM
#40
ONLINE
#41
OFFLINE
#42
OFFLINE
#43
ONLINE
Posted July 21, 2013 - 03:38 PM
You may be better off taking all that wiring out and going back to the oem key and push button starter.
The original push button starter acted as the solenoid so you could eliminate the one that someone cobbled on there.
#44
OFFLINE
Posted July 21, 2013 - 05:08 PM
I was thinking of just adding a (universal) push button switch for the starting and using the key switch just to turn on the ignition. Bolens 1000, can you tell me where the wire goes that comes from theignition to the right side of the engine? I don't see this on the diagram anywhere?
#45
OFFLINE
Posted August 18, 2013 - 06:36 AM
Help?
