Bolens "husky 800"
95 replies to this topic
#1 woopud OFFLINE
woopud
  • 74 Thanks
  • 167 posts
Posted June 25, 2013 - 05:18 PM
Picked this up today!  Supposedly it only needs a ignition coil to run.
  • Gtractor, OldBuzzard, hamman and 1 other said thanks
#2 Bolens 1000 ONLINE
  • 17541 Thanks
  • 18861 posts
Posted June 25, 2013 - 05:25 PM
Its a 1963
Originally did not come with electric start... Looks like someone did a few modifications and added the starter and switch.
Besides the bad paint job someone did  it looks to be a decent machine thats complete
#3 A.C.T. OFFLINE
A.C.T.
    Another Classic Tractor
  • 2365 Thanks
  • 2496 posts
Posted June 25, 2013 - 05:28 PM
#4 superaben OFFLINE
superaben
    Con Man
  • 7672 Thanks
  • 5677 posts
Posted June 25, 2013 - 06:21 PM
Is it battery ignition or magneto ignition?  If it is battery ignition you can buy a standard coil from an auto parts store for a couple bucks and be good to go.  If it is magneto ignition I think the S7 used a Wico under flywheel mag, if I remember right.
Ben W.
#5 Sawdust OFFLINE
Sawdust
  • 6801 Thanks
  • 3799 posts
Posted June 25, 2013 - 07:59 PM
Good looking little GT...nice find.
#6 bread320i OFFLINE
bread320i
  • 614 Thanks
  • 1225 posts
Posted June 25, 2013 - 08:59 PM
Its odd that the Wisconsin engine Model is S-7 and not S-7d as I  am used to seeing.
#7 woopud OFFLINE
woopud
  • 74 Thanks
  • 167 posts
Posted June 25, 2013 - 10:03 PM
Ben W.
I'll take out the coil tomorrow and see if I can find the problem, is there a way to rest it?
#8 1967bolens collector OFFLINE
    Deceased
  • 663 Thanks
  • 1441 posts
Posted June 26, 2013 - 03:47 AM
not bad looking machine.. is it your first bolens?
#9 woopud OFFLINE
woopud
  • 74 Thanks
  • 167 posts
Posted June 26, 2013 - 05:36 AM
Yes, this is my first Bolens, also have a 1983 Sears GT 16.   So, I typed in the serial of the engine and it came up as being build in January of 1962.
#10 Bolens 1000 ONLINE
  • 17541 Thanks
  • 18861 posts
Posted June 26, 2013 - 06:03 AM
Hard to tell from the pics but is there an on and off toggle switch added anywhere?
Since electric start was added the guy may have just wired the tractor wrong and your coil coil be good.
The original switch only had  1 terminal  for on/off and looks like the guy cobbled together a multi prong switch.
#11 Bolens 1000 ONLINE
  • 17541 Thanks
  • 18861 posts
Posted June 26, 2013 - 06:10 AM
This would indicate you have an original engine
The engines used were generally 1 year older than the tractors themselves
#12 superaben OFFLINE
superaben
    Con Man
  • 7672 Thanks
  • 5677 posts
Posted June 26, 2013 - 06:14 AM
I was thinking the same thing.  Usually Wisconsin added a "D" at the end of a model to show that it had stellite valves.  My Wisconsin folder doesn't mention an S-7, but maybe it predates what I have.
Not easily unless you have one of those magneto coil testers from the 1950's.  If it is battery ignition see if you are getting 12 volts to the coil.
Ben W.
#13 woopud OFFLINE
woopud
  • 74 Thanks
  • 167 posts
Posted June 26, 2013 - 04:50 PM
The "key" switch has a on/off setting and a start function.  Going to take a look at it now and will post pictures.  Right now it doesn't have a battery either....
#14 woopud OFFLINE
woopud
  • 74 Thanks
  • 167 posts
Posted June 26, 2013 - 06:12 PM
How can I tell?  I guess I have to take the flywheel off to see?
#15 woopud OFFLINE
woopud
  • 74 Thanks
  • 167 posts
Posted June 26, 2013 - 06:14 PM
Ben W.
I guess I'll have to take off the flywheel to see which one it is?
