Cracked Gas Tank, Need Help
7 replies to this topic
#1 farmer john OFFLINE
farmer john
  • 1,782 Thanks
  • 906 posts
Posted June 25, 2013 - 01:42 PM
hi guys, dropped my weed eater, a stihl 106 and cracked the tank, (yeah i know its not a gt)i need help, thats what the wife says far to often, the tank is no longer available, i tried epoxy, fiberglass, jb weld,and still have gas trickling down my backside, i dont want to pull a richard prior and be running down the street in flames ha ha ha!! any other ideas? the dealers are no help all they want to do is sell me another machine for $500 and from the looks of it a piece of plastic junk. thanks for looking
  • Texas Deere and Horse, JDBrian and JRJ have said thanks
#2 Arti OFFLINE
Arti
  • 1,363 Thanks
  • 989 posts
Posted June 25, 2013 - 01:58 PM
I've used Seal All with good success. Local in Farm or Hardware Stores
  • Alc, hamman and farmer john have said thanks
#3 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,310 Thanks
  • 4,948 posts
Posted June 25, 2013 - 02:00 PM
Any of the above patches should work but you have to sand/rough up the plastic.  If the plastic is left smooth and slick nothing will stick to it.  Best of Luck!
  • hamman and farmer john have said thanks
#4 Texas Deere and Horse ONLINE
  • 14,793 Thanks
  • 15,495 posts
Posted June 25, 2013 - 02:08 PM
I have had good luck doing ABS or Plastic Welding with a soldering iron. Here's a thread we had in Jan. 2011.
http://gardentractor...lastic welding
I recently re-welded the seam on my push mower gas tank, the glue just gave up I guess.
  • Alc, hamman, HDWildBill and 2 others have said thanks
#5 jms180 ONLINE
jms180
  • 1,504 Thanks
  • 1,562 posts
Posted June 25, 2013 - 04:03 PM
I saw a guy weld up a split in plastic tank with soldering iron and strips cut from a milk container and it worked. He sanded the area split.
  • farmer john said thank you
#6 MH81 OFFLINE
Posted June 25, 2013 - 04:13 PM
Couple of products ive had good luck with here http://gardentractor...on/#entry267981
#7 farmer john OFFLINE
farmer john
  • 1,782 Thanks
  • 906 posts
Posted June 25, 2013 - 08:03 PM
thanks all i pulled out the soldering iron and and old tank, a little patch uses up a lot of material, fixed the one small crack about 1 inch long be now found a 3 inch one, will attemp that one tomorrow,
  • olcowhand, MH81 and Texas Deere and Horse have said thanks
#8 HDWildBill OFFLINE
  • 8,975 Thanks
Posted June 25, 2013 - 08:45 PM
I've been using this Kit from HF with quite a bit of success,  To reinforce your welded area you can imbed wire screen or cotter pins into the plastic and then over lay it with additional plastic.  You do have to be careful that the plastic you are using is compatible with the plastic your are repairing.
