Need Tips Front Pto Replacement Jd 318
3 replies to this topic
#1 K3522 OFFLINE
K3522
  • 7 Thanks
  • 21 posts
Posted June 25, 2013 - 01:36 PM
Just bought new front PTO. Any tips I should know?
Remove center bolt, remove 4 outer bolts and should pry off?
  • JRJ said thank you
#2 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,773 Thanks
  • 4,265 posts
Posted June 25, 2013 - 01:55 PM
better you had bought a rear pto. therefore I have a PSI - sorry, can't realy help you,  j/k
#3 olcowhand ONLINE
  • 41,261 Thanks
  • 31,447 posts
Posted June 25, 2013 - 02:28 PM
Sometimes it'll all come off together, but more often than not, you need to pull off the pulley first, then the keyed drive plate, then the electromagnet from the block.  Sometimes a puller is needed even, but usually only a slight pull is required.
#4 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted June 25, 2013 - 02:33 PM
Check your PM. I'm sending you some info. that should help.
