Sears Tractor Help
sears 79 tractor help
7 replies to this topic
#1 Veeda OFFLINE
  • 4 Thanks
  • 1 posts
Posted June 24, 2013 - 09:54 PM
Me and my dad bought this tractor for 200 dollars and have been fixing it up got an extra motor ferrer dics snow plow and wheel weights and 2 mower decks if any one has any specs on belt sizes and size of blades I will need please send me info I would really Appreciate it thanks so much it set for 10 years out in the rain n snow and we had it running in 2 days we love this tractor
  • MH81, hamman, boyscout862 and 1 other said thanks
  • 29,970 Thanks
Posted June 24, 2013 - 10:01 PM
:welcome: to GTTalk
Darned Sharp looking Sears, you guys put some real time into it.
Do you have #'s on the Mower and Tractor models?
#3 crittersf1 OFFLINE
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted June 25, 2013 - 04:27 AM
#4 KennyP OFFLINE
  • 39,027 Thanks
  • 46,259 posts
Posted June 25, 2013 - 04:53 AM
Welcome to the forum! Nice looking tractor. Model #'s will help a lot on figuring things out!
#5 boyscout862 OFFLINE
  • 13,191 Thanks
  • 9,279 posts
Posted June 25, 2013 - 07:21 AM
Welcome to GTT. Check out our "Manuals" section for some info. Good Luck, Rick
#6 robert_p43 OFFLINE
  • 572 Thanks
  • 534 posts
Posted June 25, 2013 - 07:47 AM
That's a beauty, sorry I can't help with specs without the numbers.  Even then, I may only be able to find part numbers, not sizes for you.  Someone more knowledgeable here can, I am sure.  They sure have helped me whenever I have need assistance.
#7 WNYTractorTinkerer OFFLINE
    Tinker Master
  • 10,642 Thanks
  • 5,842 posts
Posted June 25, 2013 - 08:26 AM
Sure pops into the forum with a hoot of a question huh??  If no information is available take a string and wrap it around the pulleys and mark/measure..  You may have a few trips to the store for he thing but it should get ya going iif you can't find the model##
  • 8,014 Thanks
  • 5,694 posts
Posted June 25, 2013 - 09:51 AM
From the looks of the dash, foot boards, and hood, I'm suspecting that is a '67 SS12, looks like you got it clean up very nice.
You can look on the motor, on the mounting base front left, kind of under the flywheel/carb area, there will be a number stamped in the oil pan right above frame, that will give you horsepower rating of the motor.
Here is a couple sites that still sells blade that will fit the 42" Sears decks. Guuy I know bought them, he was using them to "bush hog" some high grass and was very impressed.
Belts... I list different sizes as I've seen many people use both sizes with success, there was some belt length differences as Sears changed pulley sizes related to motors used. I also think it may be due to aftermarket, off shelf different brands, etc. I buy Kevlar belts from TSC for my needs.
I think your 12Hp may take the 81"  engine to tranny belt and probably the 101" engine to deck.
Starter/gen - 3/8"X 33"
Main drive, engine to tranny- 1/2"x 81, 82 or 83"
Deck pulleys belt- 1/2"x 92"
Engine to deck-  5/8" x 101, 102 or 103"
