My Jd317--Good News And Bad News
jd317 flywheel alternator oil filter
17 replies to this topic
#16 jdslednut OFFLINE
jdslednut
  • 680 Thanks
  • 851 posts
Posted June 24, 2013 - 06:42 PM
I have a flywheel! At least I'm pretty sure. However, I'm away from home until Wednesday. I'll let it go for a lot cheaper than a hundred bucks. If you want to hold off unil I can get you a picture ill do that when I get back. Don't know if I have a stator though. I don't remember but can check in a few days.
Edited by jdslednut, June 25, 2013 - 12:43 AM.
  • olcowhand and Utah Smitty have said thanks
#17 Utah Smitty OFFLINE
Utah Smitty
  • 1,713 Thanks
  • 1,793 posts
Posted June 25, 2013 - 05:04 AM
Thanks so much!!.  I'm interested... let me kno w when you can.
Smitty
#18 Utah Smitty OFFLINE
Utah Smitty
  • 1,713 Thanks
  • 1,793 posts
Posted July 02, 2013 - 04:03 PM
Well, I decided I would probably use this 317, instead of trying to get the other one back in shape.  I don't need 2 of them, but one will provide a good source of parts for the other.
I hauled it to a car wash and cleaned it off as best I could--there was crusted on oily dirt everywhere underneath.  In the process, I managed to break the clear line that shows the transaxle oil level--it was pretty brittle, and needed to be replaced.
The body pan was only held on by two bolts, so I decided to remove it so I could more easily work on the transaxle, etc.
When I got the body off, I discovered this:
I've never known of a metal fan to break like this unless it's physically damaged.  The broken-off blade was lying in the bottom of the fan shroud--completely buried in crud...
Now, a couple questions:
How do you remove the fan??? this one had a nylon wire tie through the hole up by the pump, I removed it, but the fan hub seems to be pressed on.
How do you drain the transaxle.  There's a big hex nut at the very back, about even with the axles, but it wouldn't drain much from that... do you break a line free?
As always, any help would be appreciated.
Smitty
Also tagged with one or more of these keywords: jd317, flywheel, alternator, oil filter
