Springfield Model ?
8 replies to this topic
#1 willy OFFLINE
willy
  • 73 Thanks
  • 86 posts
Posted June 23, 2013 - 12:51 PM
  I do not know model or year , motor was a briggs now trash . Belongs to a friend . I know the seat spring is not stock .
  • Texas Deere and Horse, hamman, JRJ and 1 other said thanks
  • 14,594 Thanks
  • 15,426 posts
Posted June 23, 2013 - 01:06 PM
Member Wvbuzzmaster will know for sure, as I can't tell you. The tractor looks to be in nice shape and just needs to be cleaned up and painted, even the fenders look good. Good Luck !!
#3 DougT ONLINE
DougT
    Dog Approved
  • 6,567 Thanks
  • 4,741 posts
Posted June 23, 2013 - 01:49 PM
If you know the HP or any other info from the original engine, it would help in I.D.ing it.
#4 pwombles OFFLINE
pwombles
  • 201 Thanks
  • 220 posts
Posted June 23, 2013 - 04:26 PM
Its a model 36 , should of originally had a 6hp Kohler Vertical as it has the grille extention/riser. should be 62,63 or 64.
#5 pwombles OFFLINE
pwombles
  • 201 Thanks
  • 220 posts
Posted June 23, 2013 - 04:27 PM
2, 1962"s in my avatar Pic
#6 willy OFFLINE
willy
  • 73 Thanks
  • 86 posts
Posted June 23, 2013 - 06:27 PM
   Thanks  Did the Kohler's  & Briggs have the same mounting pattern , there is only one set of holes .
#7 pwombles OFFLINE
pwombles
  • 201 Thanks
  • 220 posts
Posted June 23, 2013 - 09:42 PM
not sure on that one. maybe someone else can answer that one for you.
#8 wvbuzzmaster OFFLINE
  • 4,663 Thanks
  • 7,409 posts
Posted March 20, 2014 - 06:25 PM
I missed this for some time. The year is 1963, as the front axle is straight and grill is smooth. This would be a model 63te-6 Springfield. The engine would have been a briggs 6hp model number 146701 or 146702, only difference is rope start vs electric start. However, a 7hp Briggs model 17---- is easier to find and bolts up just fine. Good luck with it.
Edited by wvbuzzmaster, March 20, 2014 - 06:28 PM.
#9 wvbuzzmaster OFFLINE
  • 4,663 Thanks
  • 7,409 posts
Posted May 04, 2015 - 02:18 AM
Make any progress on the Springfield lately?
