Oil Filter Question Gt 275
11 replies to this topic
#1 backwoods OFFLINE
backwoods
  • 2,622 Thanks
  • 2,816 posts
Posted June 23, 2013 - 10:36 AM
i was wondering if my only option was to go through the dealer or if there was a part number for a filter that will fit and work from walmart or napa? its a GT 275 17hp kawi
  • JRJ said thank you
#2 jd.rasentrac ONLINE
jd.rasentrac
  • 4,797 Thanks
  • 4,292 posts
Posted June 23, 2013 - 11:06 AM
hi Greg, this was the same, or?   Attached File  fb_MaintSheet_gt275_48deckLawnTractor.pdf   253.76KB   131 downloads
Edited by jd.rasentrac, June 23, 2013 - 11:11 AM.
  • HDWildBill and backwoods have said thanks
#3 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted June 23, 2013 - 11:07 AM
What's the # and I'll see if I can cross it.
  • backwoods said thank you
#4 jd.rasentrac ONLINE
jd.rasentrac
  • 4,797 Thanks
  • 4,292 posts
Posted June 23, 2013 - 11:12 AM
AM107423 ........... ENGINE OIL FILTER
here's JDPC John Deere - GT275oilfilter.jpe
  21 AM107423 Oil Filter
Edited by jd.rasentrac, June 23, 2013 - 11:19 AM.
  • HDWildBill, backwoods and JRJ have said thanks
#5 backwoods OFFLINE
backwoods
  • 2,622 Thanks
  • 2,816 posts
Posted June 23, 2013 - 11:26 AM
thanks guys i guess since ive put 200hrs on it i should change the oil
#6 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted June 23, 2013 - 11:42 AM
Greg I am using a PH4967 Fram, there is also the Wix 51394 for that Gt275.
Dick
#7 backwoods OFFLINE
backwoods
  • 2,622 Thanks
  • 2,816 posts
Posted June 23, 2013 - 11:54 AM
thanks JRJ what oil do ya use as well 5w30 or 10w30?
#8 jd.rasentrac ONLINE
jd.rasentrac
  • 4,797 Thanks
  • 4,292 posts
Posted June 23, 2013 - 01:16 PM
are you using the gt in winter, too? then 5w30 will be better  viskositaetsbereiche_motoro.jpg
Edited by jd.rasentrac, June 23, 2013 - 01:16 PM.
  • HDWildBill said thank you
#9 olcowhand ONLINE
  • 42,369 Thanks
  • 31,793 posts
Posted June 23, 2013 - 01:45 PM
Dick
Yep, those are correct!
#10 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted June 23, 2013 - 05:05 PM
olcowhand-did you  have any doubt.
Dick
#11 olcowhand ONLINE
  • 42,369 Thanks
  • 31,793 posts
Posted June 23, 2013 - 05:36 PM
Dick
Why no, I truly didn't, but it helps a member feel better when other's back up a fella's word!  :thumbs:
#12 backwoods OFFLINE
backwoods
  • 2,622 Thanks
  • 2,816 posts
Posted June 25, 2013 - 09:14 AM
also helps when someone on the form has the same tractor as well. yes itll be used year round snow duty in the winter but from what ive read every 200hrs i need to change the oil&filter does that sound normal?
