Overkill !
24 replies to this topic
#16 A.C.T. OFFLINE
A.C.T.
    Another Classic Tractor
  • 2,364 Thanks
  • 2,496 posts
Posted June 22, 2013 - 10:03 PM
At least the Cub can mow!
  • larryd said thank you
#17 glgrumpy ONLINE
  • 8,605 Thanks
  • 7,913 posts
Posted June 22, 2013 - 10:05 PM
Am I seeing that right and the bellhousing end of engine is in Front?? No radiator, so this is a 10 minute make a quick run and shut it off dragster or puller?? Wonder what other components were used for clutch and trans??  Must all run off the front of engine then?  Wonder if this isn't a non-operable "look at me" type of unit. Looks great, but can't Cook!
#18 Marty'70 OFFLINE
Marty'70
    I didn't do it! Unless you have paperwork to back it up
  • 862 Thanks
  • 719 posts
Posted June 22, 2013 - 10:33 PM
All that fabrication work and then use a Furd engine???????
First On Race Day. Oh and you spelled Ford wrong... :hitting_self_roller:
  • limebuzz and larryd have said thanks
#19 backwoods ONLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted June 23, 2013 - 10:25 AM
hes a chevy guy hes doesnt know any better lol it would have been cool if they did use an old scout engine though
#20 UncleWillie OFFLINE
  • 15,663 Thanks
  • 8,758 posts
Posted June 23, 2013 - 11:37 AM
Chevy's are made to tow broken Fards home.
  • Amigatec and larryd have said thanks
#21 chaentjens OFFLINE
chaentjens
  • 101 Thanks
  • 122 posts
Posted June 23, 2013 - 01:15 PM
F'ed Over Rebuilt Dodge. Found On Road Dead. Lol
Sent from my SPH-L900 using Tapatalk 4 Beta
#22 Marty'70 OFFLINE
Marty'70
  • 862 Thanks
  • 719 posts
Posted June 23, 2013 - 09:15 PM
10-4 on the binder power
#23 916 hydro OFFLINE
916 hydro
  • 114 Thanks
  • 139 posts
Posted June 24, 2013 - 09:56 AM
maybe its on alcohol and doesn't need the cooling system? or is that possibly a radiator mounted on the back?
#24 twostep OFFLINE
twostep
    Rockstar
  • 1,984 Thanks
  • 2,535 posts
Posted June 24, 2013 - 11:51 AM
it looks like a remote mount oil filter housing to me. you can see the oil filter on it with a inlet line and outlet line.
yup, you can see the fram filter under it.
Since it has a dummy bellhousing out front I guess it's turning a pully off the "front" of the engine... wonder how you start it.
#25 Sandburr OFFLINE
Sandburr
  • 35 Thanks
  • 46 posts
Posted June 24, 2013 - 02:30 PM
I do not believe that is a dummy bellhousing. That engine is sitting backwards, since the distributor on Fords are on the front. One still has to wonder if it actually pulls itself.
