My Newest Acquisition--Jd420
jd420 john deere john deere 317 loader front end loader steering king pin spindle fel
23 replies to this topic
#1 Utah Smitty OFFLINE
Utah Smitty
  • 1,707 Thanks
  • 1,791 posts
Posted June 20, 2013 - 10:44 PM
This thread is actually a continuation of one on Diesel tractors where I told of my first ride on a diesel Gt, and also the three JDs I recently bought-- 2 JD317s, and a 420.
I have some questions on the 420 and thought it best to start a new thread.
First off, here's a picture of the tractor, and some pics of the attachments--including a modified Johnson FEL.  It also came with a 60" deck, 3ph, scraper blade, dethatcher and aerator.
The B48 Onan runs well, though it blows a little blue smoke when you rev it up.  The hydro has what I would consider to be normal hydro whine, and the power steering and hydraulics all work.
However, as is the case whenever you buy something used, you always find little problems after you get it home.  In this case, my biggest concern right now is that the front axle is badly worn on the right side--clear thru the bushing where the kingpin goes into the axle-- see picture.
Is this something that can be repaired? If so, how?  I need to use the front end loader and am concerned about boring out the axle and sleeving it as the thinner walls might crack...
I'd appreciate any suggestions.
Regards,
Utah Smitty
Edited by Utah Smitty, June 21, 2013 - 09:20 AM.
  • Texas Deere and Horse, A.C.T. and HvrubchevskayaPn have said thanks
  • 14,863 Thanks
  • 15,511 posts
Posted June 20, 2013 - 11:16 PM
Smitty, I would get it torn down and really see what you have. Maybe the spindle is worn and not the axle. I'm sure one of our Site Sponsors has a good axle if you need one.
That is one great looking 420 and attachments you got there. :thumbs:
  • Utah Smitty said thank you
#3 A.C.T. OFFLINE
A.C.T.
    Another Classic Tractor
  • 2,364 Thanks
  • 2,496 posts
Posted June 21, 2013 - 12:14 AM
Utah Smitty : 1   A.C.T. : 0
Congrats!
#4 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted June 21, 2013 - 05:23 AM
Very nice Smitty. Attachments !! You got a real nice package there. The loader puts a lot of stress on the front end. That spindle looks all wrong somehow. I wonder if someone took the bushing out and never replaced it. Have you checked the parts diagrams on JDParts.com to see if the bushings are still available. They are replaceable and should wear faster than the spindle. I think the spindles would be available used from our sponsors.
#5 KennyP OFFLINE
  • 40,192 Thanks
  • 46,794 posts
Posted June 21, 2013 - 05:45 AM
Smitty, I'm with TD&H. Pull the spindle and see what you really have. If the axle hole is out of round, might be worthwhile to find a new axle since you have a loader for it!
#6 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted June 21, 2013 - 08:33 AM
I have to agree with others and say break it down and see what you have got.
If I remeber right those are bushings and not bearings in the axle. As long as the Spindle is not worn or has not worn into the axle casting it should just need new bushings pressed in. And as long as it is not excessive I don't think you would weaken the axle by reaming and going slightly oversize on the bushings.
That is one tough axle!
In a worst case Scenario(Hate to even suggest that)  The P.F. Engineering site, google it (they sell plans for loaders and backhoes for GT's)
They have a section called "2,000 lb spindle mods" that offers several methods of modifying the spindles for heavy use.
They use traier axle stubs and hubs.
Good luck you have the machine I have dreamed about on my little acreage!!
Edited by JD DANNELS, June 21, 2013 - 08:35 AM.
  • KennyP and Utah Smitty have said thanks
#7 hdg4400 OFFLINE
hdg4400
  • 286 Thanks
  • 351 posts
Posted June 21, 2013 - 08:34 AM
Smitty:
Nice tractor and attachments, though I have had trouble with the smell of diesel ever since I rode a Grayhound bus straight thru and back to Washington DC. That was almost 50 years ago.
I agree with the advice above, check the spindle for a worn bushing. I replaced the bushings in my JD 318, and it made a big difference. I found the part number in JDParts, and then found a supplier, MFG Supply, online.
They were $2.85 apiece and the shipping was $6.99.
By the way, I have the 420 Operator's Manual as a PDF, if you want it.
Harlan
Edited by hdg4400, June 21, 2013 - 08:54 AM.
#8 Utah Smitty OFFLINE
Utah Smitty
  • 1,707 Thanks
  • 1,791 posts
Posted June 21, 2013 - 09:24 AM
Ah, yes, and you have the acreage I've dreamed about!!
Some friends in our church have let us use part of their land for a garden.  I offered to keep the pasture there mowed to return the favor.  The JD 420 comes in very helpful in that regard!!!
Regards,
Smitty
#9 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted June 21, 2013 - 10:24 AM
n
Regards,
Smitty
Well the acreage was a life long dream that I had nearly given up on.  When I lost my home in 2010 I had to relocate.
After looking at 45 places that did not seem right. This one came up and seemed out of reach. They wanted $10,000 more Than I could spend and they had already come down $12,000 off original price..  I offered them $7,000 less than they wanted and was amazed when they took it?    I could not possibly have bought it if God had not interceeded on my behalf!!
Edited by JD DANNELS, June 21, 2013 - 10:25 AM.
  • twostep said thank you
#10 Utah Smitty OFFLINE
Utah Smitty
  • 1,707 Thanks
  • 1,791 posts
Posted June 21, 2013 - 10:35 AM
Indeed!!  The Good Lord has interceded for me many times...more than I can remember.  I guess when things are right I'll be able to realize that dream as well.
Smitty
#11 Utah Smitty OFFLINE
Utah Smitty
  • 1,707 Thanks
  • 1,791 posts
Posted June 21, 2013 - 10:38 AM
Well, it looks like the spindle is badly worn, as is the axle-- clear through the bushing and into the bore... I've found several axles for sale at reasonable prices, including one for a 430 at Joe's --will it fit the 420?
My next concern is the spindle.  Haven't found any for a 420.  There are some for a 400 and a 425.  Will these fit in okay?  I don't mind having to modify the tie rod brackets.
Thanks,
Smitty
#12 olcowhand ONLINE
  • 42,455 Thanks
  • 31,824 posts
Posted June 21, 2013 - 11:32 AM
All front axle components of the 420 & 430 are identical parts, axle beam, spindles, bushings....everything.  400 & 425 ARE NOT a MATCH ON ANYTHING.
#13 Utah Smitty OFFLINE
Utah Smitty
  • 1,707 Thanks
  • 1,791 posts
Posted June 21, 2013 - 11:46 AM
Thanks, Daniel, good to know.
I'll get the one from Joe's, then work on repairing this spindle or making another.
Smitty
#14 olcowhand ONLINE
  • 42,455 Thanks
  • 31,824 posts
Posted June 21, 2013 - 01:20 PM
I looked up all the parts online to be sure.  I didn't want to go by my gut feeling.
#15 Utah Smitty OFFLINE
Utah Smitty
  • 1,707 Thanks
  • 1,791 posts
Posted June 26, 2013 - 08:44 PM
Well, I finally got the FEL installed.  Then I loaded it up to go and clean it off at the car wash.  Here's a couple pics.
SmittyIMG_20130625_200447_938.jpg IMG_20130625_200508_954.jpg IMG_20130625_200518_823.jpg
Also tagged with one or more of these keywords: jd420, john deere, john deere 317, loader, front end loader, steering, king pin, spindle, fel
