Help- 317 Re Power With Kohler Command 20
6 replies to this topic
#1 oldman OFFLINE
oldman
  • 11 Thanks
  • 25 posts
Posted June 20, 2013 - 09:13 PM
I bought a 1982 317 with no engine. I have found a Kohler Command 20 in good shape. My question is with the Kohler Command will the exhaust pipes be facing towards the front of the tractor? I am a little confused about the difference in the two engines as far as engine rotation. The more I think about it the more it confuses me.
Help,
Oldman
#2 Utah Smitty OFFLINE
Utah Smitty
  • 1,701 Thanks
  • 1,781 posts
Posted June 20, 2013 - 10:17 PM
Help,
Oldman
I have a 317 with a Kohler Magnum 18 in it. The engine sits in the tractor backwards. The driveline connects to the front (fan side) of the engine, and the PTO connects to the crankshaft.
The exhaust pipes and muffler are at the front of the tractor... there's a heat shield between the muffler and the engine.
Take pictures of your project--I'd like to see how things go together.
Utah Smitty
Edited by Utah Smitty, June 20, 2013 - 10:18 PM.
#3 oldman OFFLINE
oldman
  • 11 Thanks
  • 25 posts
Posted June 20, 2013 - 10:28 PM
I appreciate your response. I do not know why this was so confusing to me.
I will get started on it this week-end and I will post some photographs.Did you install the Magnum or was it already in the tractor when you got it?
#4 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted June 21, 2013 - 05:28 AM
I'd be interested in your repower as well. I have a 79 with a series 1 engine that is still running pretty well but it's days are numbered. The flywheel side drives the hydro and the crank drives the PTO as Smitty said. You will need some sort of adapter to connect the flywheel to the drive shaft.
  • oldman said thank you
#5 oldman OFFLINE
oldman
  • 11 Thanks
  • 25 posts
Posted June 21, 2013 - 07:54 AM
As soon as I get started I will post pictures. Thanks for answering.
#6 Utah Smitty OFFLINE
Utah Smitty
  • 1,701 Thanks
  • 1,781 posts
Posted June 21, 2013 - 09:31 AM
It was already in the tractor when I bought it (last week!!)  It fits very well, looks like OEM.  The only thing I noticed was a slight notching of the frame (about the size of a dime) to keep the stud on the starter from hitting the frame.
Regards,
Smitty
#7 Utah Smitty OFFLINE
Utah Smitty
  • 1,701 Thanks
  • 1,781 posts
Posted June 21, 2013 - 10:09 AM
I'm not positive, but the Command 20 may have the bolt pattern to use the old flywheel adapter from the KT17-- would save from having to "roll your own".
Smitty
Edited by Utah Smitty, June 21, 2013 - 10:10 AM.
  • JDBrian and oldman have said thanks
