Onan Djb 2Cyl Air Cooled Diesel For Repower... Thoughts?
19 replies to this topic
#1 twostep OFFLINE
twostep
    Rockstar
  • 1,970 Thanks
  • 2,528 posts
Posted June 20, 2013 - 02:06 PM
Does anyone have any thoughts on using a 2 cylinder air cooled Onan DJB for a GT repower? Looks like they are 0.98 liter so that is pretty good size, specially for 2 cylinders. Seems like (due to low rpm) it would only be useful for hydraulic drive.
From what I've found, they are rated at 11.8hp and 0.6 gal/hr @ 1800rpm.
Any thoughts?
  • Texas Deere and Horse and JRJ have said thanks
#2 olcowhand ONLINE
  • 40,349 Thanks
  • 31,170 posts
Posted June 20, 2013 - 02:14 PM
Never heard of them!
  • 14,730 Thanks
  • 15,470 posts
Posted June 20, 2013 - 02:33 PM
What is the operating RPM's?
#4 olcowhand ONLINE
  • 40,349 Thanks
  • 31,170 posts
Posted June 20, 2013 - 02:37 PM
Get your glasses on Brian, he said 1,800 rpm!  :smilewink:   The low rpm would be a snag.  Half normal of most any garden tractor, but if used in belt drive, no problem, just pulley down to double the shaft speed & you'd be good to go.  I can't say, but this engine "might" be able to run faster, but I have no way of knowing for sure.
  • 14,730 Thanks
  • 15,470 posts
Posted June 20, 2013 - 02:51 PM
Thanks Daniel, I didn't fully read the last line. :wallbanging: :rolling:
#6 twostep OFFLINE
twostep
    Rockstar
  • 1,970 Thanks
  • 2,528 posts
Posted June 20, 2013 - 02:59 PM
Here are a couple of links where I found info:
http://www.google.co...u9LHpAgq4Uf5ENQ
http://www.google.co...Ee2nmD6RneSxX_A
Looks like they are constant speed with either single speed or 2 speed governor. Operating speed is 1800rpm up to 2400rpm (power and fuel info is @ 1800).
  • 14,730 Thanks
  • 15,470 posts
Posted June 20, 2013 - 03:05 PM
2,400 is a lot closer to where you need to be. What are you re-powering, is it direct drive or belt?
#8 olcowhand ONLINE
  • 40,349 Thanks
  • 31,170 posts
Posted June 20, 2013 - 03:11 PM
I'm "usually" the world's worst at not reading entire posts before abusing my keyboard!   But not this time!  :D
#9 twostep OFFLINE
twostep
    Rockstar
  • 1,970 Thanks
  • 2,528 posts
Posted June 20, 2013 - 03:13 PM
Nothing yet... Actually I've been keeping my eyes open for a 2cyl kubota for repowering the 140 (packaging will be :wallbanging: if not impossible). I just happen to find one of these engines for a pretty good price.
#10 olcowhand ONLINE
  • 40,349 Thanks
  • 31,170 posts
Posted June 20, 2013 - 03:15 PM
Between the identical engines on my 430 vs 935, there is a 300rpm difference, making a 10% rise in HP.  If this held for this engine, then the 600rpm would convert to 20% rise, so 11.8 x 1.20 would = 14.6HP @ 2400rpm.
  • twostep said thank you
#11 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted June 20, 2013 - 03:17 PM
Like Daniel said, If it is going to be belt driven, you can gain back the RPM's in the sheave ratio.
#12 olcowhand ONLINE
  • 40,349 Thanks
  • 31,170 posts
Posted June 20, 2013 - 03:18 PM
Hey, I know it can be done!  Where there's a will, there IS a way!
#13 JDBrian OFFLINE
  • 9,601 Thanks
Posted June 20, 2013 - 07:51 PM
Sounds like it was a gen set engine. They have strange model numbers. 3 letters instead of a typical Onan model like P218 for instance.  The gas Onans designed for gen sets have a huge flywheel and a slightly lower compression ratio. I've got one in my garage right now. I thought it would be useful for a GT repower but I don't think it's worth all the trouble. I don't think I'd try to spin that big flywheel at 3000+ rpms. I'm not sure if the diesels could be sped up enough to run a hydro properly. You may be able to trade it or get a good price for it as they were used a lot in RVs.
#14 skyrydr2 OFFLINE
  • 3,869 Thanks
  • 3,401 posts
Posted June 21, 2013 - 03:49 AM
Ive seen them on military generators only! I think it was built specifically for these units. The ones I saw were vertical twins not opposed too. And were huge honkin' things that would be a real challenge to fit into a gt .
#15 JDBrian OFFLINE
  • 9,601 Thanks
Posted June 21, 2013 - 05:04 AM
I've seen the opposed diesels for sale here on Kijiji. They are huge as well. No way the width could be kept inside the engine covers, even on a Ford or JD. I'm not sure what the crankshaft is like on them. If they were used with a single bearing gen head then it's going to have a tapered shaft. Would be a torque monster though!
