Acquired A Nos Loader-Mounted Hydraulic Front Blade Today
20 replies to this topic
#16 ajs96 OFFLINE
ajs96
  • 14 Thanks
  • 11 posts
Posted June 20, 2013 - 01:11 PM
Where is this Jerry at in TEXAS? I need to go by and see him sometime.
He's in Taylor, TX
His Ebay store is USSUPPLY         http://www.ebay.com/...ussupply/m.html
His website is         http://powerkingtractorbarn.com/
  • Alc and Texas Deere and Horse have said thanks
#17 Texas Deere and Horse OFFLINE
  • 14,811 Thanks
  • 15,500 posts
Posted June 20, 2013 - 01:52 PM
Not too far north of me above Bastrop, TX.
Where are you located at?
#18 ajs96 OFFLINE
ajs96
  • 14 Thanks
  • 11 posts
Posted June 20, 2013 - 01:54 PM
I'm northwest of Georgetown
#19 Texas Deere and Horse OFFLINE
  • 14,811 Thanks
  • 15,500 posts
Posted June 20, 2013 - 01:56 PM
Just a quick trip north of me up IH130.
#20 glgrumpy OFFLINE
  • 8,610 Thanks
  • 7,920 posts
Posted June 20, 2013 - 05:37 PM
I had one of those that I made from orig drawings and used a standard dozer blade. I had it for tractor in my Avatar. Never got to push snow with it, sold it in fall. I did try to push some gravel in drive a little just to see it work. That part about locking one cylinder along the side of arms didn't seem right to me. Guess tho, the fluid just passes by and goes to next movable object in system. It did work!  The whole thing is only bolted on by the orig bucket swivel holes and bolts. The metal rests against the back of the arms, pressed there just by the weight of it. Never thought of downpressure, but guess that might make it move away from the arms.
#21 ajs96 OFFLINE
ajs96
  • 14 Thanks
  • 11 posts
Posted June 20, 2013 - 06:00 PM
You're right about it pitching away from the arms on downpressure, that's exactly what happens.  It still works, but it could work better.
It's pretty common to lockout and isolate other areas of a hydraulic system, especially if they are on a shared single spool or something like that.  I had a couple of GT's that were designed to lock the deck lift cylinder in order to use the three point in the back.  It makes the non-locked cylinders move stronger and faster.
