Sears St16
25 replies to this topic
#16 MH81 ONLINE
  • 28,390 Thanks
  • 29,103 posts
Posted June 21, 2013 - 10:08 PM
well i have tune the carb bowl fule in take thing to the what they had it at when it came out of the factorie what i really need is to get a needle spring
The spring that keeps it from adjusting itself?
#17 minimac1010 OFFLINE
minimac1010
  • 3 Thanks
  • 11 posts
Posted June 22, 2013 - 10:18 AM
I meant the float needle spring is what i need too much fule is running throught it and every time i use it i smell like i just bathed in gas.
#18 MH81 ONLINE
  • 28,390 Thanks
  • 29,103 posts
Posted June 22, 2013 - 10:47 AM
Have you checked the float to make sure it isn't leaking or has fluid in it? I think it should be able to overcome the pump pressure even without the spring before it overflows.
#19 MH81 ONLINE
  • 28,390 Thanks
  • 29,103 posts
Posted June 22, 2013 - 11:11 AM
Oh, and I got the chance to look at the 16's spring.
Mine
Yours
#20 minimac1010 OFFLINE
minimac1010
  • 3 Thanks
  • 11 posts
Posted June 23, 2013 - 11:45 AM
ya it isnt leaking what i did a couple of weeks ago i had the carb of and i had tuned the needle that sits in the bowl that lets the amount of fule that gets in the carb back to what i think my ag teacher said it should be at but i havnt ran it sense.
#21 minimac1010 OFFLINE
minimac1010
  • 3 Thanks
  • 11 posts
Posted June 23, 2013 - 11:47 AM
also im sorry i havnt been on to much i been working on a car with my dad so i didnt really get a chance to and check the last few days
#22 TAHOE ONLINE
TAHOE
  • 6,737 Thanks
  • 5,098 posts
Posted June 23, 2013 - 12:52 PM
The carb on my 16 did not have a spring on the float pin if I remember right. Just the little spring like piece that actually held the needle on the float.
You sure the float is not leaking and not floating.
#23 minimac1010 OFFLINE
minimac1010
  • 3 Thanks
  • 11 posts
Posted June 23, 2013 - 04:48 PM
ok ya thats what manly im looking for so i can get that runing smoth
#24 minimac1010 OFFLINE
minimac1010
  • 3 Thanks
  • 11 posts
Posted June 25, 2013 - 10:51 AM
I ran it yesterday to mow lawn because my pos craftsman's push mower wasnt going run right all day so i said for get it charged the batteri and fired her up and thanks to the fule needle on the bottom of the carb it ran so well. (expect the part i might of put to much oil in it and it smoked quite badly for about a minute or so)
#25 minimac1010 OFFLINE
minimac1010
  • 3 Thanks
  • 11 posts
Posted August 07, 2013 - 12:51 PM
Hey guys im woundering if i just need to do some rings on my pistion to pevent any more oil burning on my lawn mower aslo if there is anything esle i need to replace please let me know so i can look for prices on it
Thanks
Minimac1010
#26 MH81 ONLINE
  • 28,390 Thanks
  • 29,103 posts
Posted August 07, 2013 - 09:42 PM
Thanks
Minimac1010
Try running sae 30 instead of multi viscosity and see if it gets better.
There actually is a test for finding out if rings will help. It works better on engines without compression release , but will work on yours well enough... Do you have a compression tester?
