416S Hitch Question
4 replies to this topic
#1 Frank Dodson OFFLINE
Frank Dodson
  • 5 Thanks
  • 12 posts
Posted June 18, 2013 - 10:51 PM
I am restoring a 416S tractor. I hope to have photos soon. The rear mechanical hitch is a tube type called a one point. I have seen sleeve hitches but never one like this. How is it used and is there any equipment out there?
Thank you.
#2 skunkhome OFFLINE
skunkhome
  • 323 Thanks
  • 455 posts
Posted June 19, 2013 - 12:11 AM
There is equipment available. Any single point of any manufacture will fit once you have the adapters, it is universal.
This is the best photo I have at the present.
http://www.ebay.com/...=item3cd221d3a6
Edited by skunkhome, June 19, 2013 - 12:14 AM.
#3 Cat385B ONLINE
    Therapy CAT
  • 12,751 Thanks
  • 9,400 posts
Posted June 19, 2013 - 04:04 AM
That tube is just Allis Chalmers' way of making a 3 point hitch back then. Allis and Simplicity rear attachments will work back there.
#4 skunkhome OFFLINE
skunkhome
  • 323 Thanks
  • 455 posts
Posted June 19, 2013 - 10:05 AM
with the sleeve adapter any single point attachemnt can be attached.   Granted early cultivators and spring tooth harrows (Ist photo) and tiller needed no adapter.  The original sleeve hitch adapters were trianglar shaped and lifting was accomplished with a chain. Great for the moldboard plow but not so much for other attachments that need to be rigid.  The newer hitch can be made rigid by tightening the jamb screws on the adapter, the attachment is lifted and controlled by a single point,   thus they are called a single point hitch.
Edited by skunkhome, June 19, 2013 - 10:12 AM.
#5 Frank Dodson OFFLINE
Frank Dodson
  • 5 Thanks
  • 12 posts
Posted June 19, 2013 - 05:44 PM
Thanks
The information was very helpful.
