Craftsman Transmission Problem
8 replies to this topic
#1 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted June 18, 2013 - 12:51 PM
My dad has a Craftsman 18 hp hydro that is ot backing up properly. It is an 18Hp Hydro.
Model 917272121 . Any idea where I can find a manual?
#2 MH81 OFFLINE
Posted June 18, 2013 - 05:15 PM
Owner's manual is here http://www.hammerwal...actor/L0709180/
but they wont say anything about the rear end. Do you know yet who made the tranny?
I think it's a Hydro Gear tranny. If so, get the model number and go looking. There are a few HG manuals here. The one in my GT6000 was a HG and after an oil/filter change, it was a different machine.
  • JD DANNELS said thank you
#3 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted June 19, 2013 - 11:47 AM
Got the manual. Your right it is a Hydro Gear Transaxle. Model 319-0650.
Will read up on it tonight.
#4 Golden Hurricane OFFLINE
Golden Hurricane
  • 16 Thanks
  • 24 posts
Posted June 19, 2013 - 12:44 PM
JD Daniels...I had a tranny that would not engage "Reverse"...Simply sprayed some WD-40 on the linkage and it has worked ever since. Before you invest a lot of time...you might spray some penetrant & lubricant on the linkage and just see if that works. Good luck & keep us posted.
  • MH81 and JD DANNELS have said thanks
#5 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted June 19, 2013 - 01:07 PM
i had this problem once on a couple of differant hydro's and found that there was a small rock caught up in the linkage.
#6 MH81 OFFLINE
Posted June 19, 2013 - 04:13 PM
Linkages can be bent too.  My GT5000 will get weird after I forget to pick up my foot before yanking "back" on the lever.  The neutral centering causes a bend in the flat steel that is the lever and I have to "tweak"it back into straight.
#7 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted July 01, 2013 - 11:45 AM
Dad called me Friday night and said the lawn tractor was fixed. Linkage was loose.
#8 Alc OFFLINE
  • 6,885 Thanks
  • 7,461 posts
Posted July 01, 2013 - 11:58 AM
Glad to hear it was a easy fix :thumbs: That's what I love about this site , you post a problem/question and  most times someone has had similar  problems  and fixes .  Even if there different answers  it gets the mind going in the right direction
#9 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted July 01, 2013 - 05:23 PM
Yeah I had downloaded the manual and printed it out for him. He told me when I took it to him that mom had cleaned the bookcase and found the manual he forgot he got when e bought it. But it got him to thinking about getting it done!
