Kohler K Compression Release
14 replies to this topic
#1 LilysDad OFFLINE
LilysDad
    --Crazy about GTTalk-- 'sort of'
  • 11,422 Thanks
  • 8,678 posts
Posted June 18, 2013 - 11:03 AM
I've mentioned before that I have a K341 that won't turn over with the starter. I got around to looking at it this morning. I pulled the head and found that the valves aren't lifting together at start up.
I don't want to tear it apart anymore than I need to. Should I go in through the side plate or the oil pan?
#2 olcowhand ONLINE
  • 37,720 Thanks
  • 30,340 posts
Posted June 18, 2013 - 11:07 AM
Only the exhaust valve pops up just a tick to drop compression.  If the exhaust valve clearance is too wide, the ACR can't work.  So checking valve clearance is the first thing to do.  .017 to .018" clearance for the exhaust.  .008 to .010" for intake while you're in there.
  • Texas Deere and Horse, JDBrian, HDWildBill and 2 others have said thanks
#3 JDBrian OFFLINE
  • 9,595 Thanks
Posted June 18, 2013 - 03:00 PM
Daniel really really knows his Kohler K series engines!  It's pretty easy to adjust the clearance and then with the cover still off and the spark plug out you can see the release working when you roll the engine over by hand.
  • LilysDad said thank you
#4 LilysDad OFFLINE
LilysDad
  • 11,422 Thanks
  • 8,678 posts
Posted June 18, 2013 - 07:43 PM
Okay, thanks! I don't have time tomorrow, but I'll check it.
#5 LilysDad OFFLINE
LilysDad
  • 11,422 Thanks
  • 8,678 posts
Posted June 19, 2013 - 07:17 PM
Your right! With the head off, and staring real hard, I could see the exhaust trying to lift. I readjusted the valves and now it obviously lifts. I need to torque the head bolts(35 ft. lbs.?) and then we'll see what happens.
#6 olcowhand ONLINE
  • 37,720 Thanks
  • 30,340 posts
Posted June 19, 2013 - 07:21 PM
25 to 30 foot pounds.
  • Texas Deere and Horse and LilysDad have said thanks
  • 14,526 Thanks
  • 15,401 posts
Posted June 19, 2013 - 07:26 PM
The manual says 25 to 30 Ft Lbs. on the head bolts.
#8 Texas Deere and Horse OFFLINE
  • 14,526 Thanks
  • 15,401 posts
Posted June 19, 2013 - 07:27 PM
Well, Daniel, I see you beat me again !! :rolling:
#9 olcowhand ONLINE
  • 37,720 Thanks
  • 30,340 posts
Posted June 19, 2013 - 08:31 PM
Yep!  :smilewink:
#10 LilysDad OFFLINE
LilysDad
  • 11,422 Thanks
  • 8,678 posts
Posted June 20, 2013 - 06:14 AM
Yah gotta' git up pretty early in the mornin' to beat a Dairyman!!! Thanks OCH!
#11 LilysDad OFFLINE
LilysDad
  • 11,422 Thanks
  • 8,678 posts
Posted June 20, 2013 - 11:36 AM
Oh, Yaas!!!  :dancingbanana:  :dancingbanana:  I'm so good! I'm so good! :dancingbanana:  :dancingbanana: The engine runs! It's been three years since I rebuilt it and it runs!
BooYah!!!
Last fall I tried to get it to go and I thought I had screwed up the rebuild. I just needed a little guidance from my milkman. :thumbs:
  • olcowhand said thank you
#12 olcowhand ONLINE
  • 37,720 Thanks
  • 30,340 posts
Posted June 20, 2013 - 11:42 AM
BooYah!!!
Ya made me laugh on a hot day of welding!  Thanks LD!  :thumbs:
#13 Guest_gravely-power_*
  • Guests
Posted June 20, 2013 - 11:45 AM
BooYah!!!
Who said milkmen stopped home deliveries?
Way to go LD
#14 LilysDad OFFLINE
LilysDad
  • 11,422 Thanks
  • 8,678 posts
Posted June 20, 2013 - 03:23 PM
Now I just need to put the tractor the rest of the way together. It's been so long, I can't find the drive/engine pulley. Anyone got a pulley for a '68 WH Charger or the equivallent?
#15 olcowhand OFFLINE
  • 37,720 Thanks
  • 30,340 posts
Posted June 20, 2013 - 03:25 PM
I hear tell there is one somewhere in Dekalb County, Illinois!   :D
