Jd160 Dies When Hot
3 replies to this topic
#1 tboogs OFFLINE
tboogs
  • 1 Thanks
  • 2 posts
Posted June 17, 2013 - 03:06 PM
My John Deere 160 mower runs well for 10-15 mins,begins to break up ,eventually stops. I've recently replaced the coil. Could this be the result of the igniter.
  • JRJ said thank you
#2 olcowhand ONLINE
  • 41,191 Thanks
  • 31,427 posts
Posted June 17, 2013 - 03:33 PM
As soon as it dies completely, have an extra spark plug with you so you can put it on the wire & check for spark.  If no spark, then either the new coil is bad, or the igniter is shot.  Chances are it's the igniter, but plenty of folks have bought brand new coils that were junk.  If there is still spark, then almost certainly a fuel issue.  Check the fuel tank cap vent hole.
  • twostep and tboogs have said thanks
#3 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted June 17, 2013 - 03:52 PM
I would check the gas cap vent 1st. that cost you nothing and an easy fix for starters.
Welcome to GTtalk.
Dick
  • tboogs said thank you
#4 Cat385B OFFLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Posted June 17, 2013 - 07:43 PM
Also tip the seat and look next to the filler neck, at the top of the fuel tank going down towards the left footrest. Is the fuel line draped above the tank in good shape? The fuel vent hose has a tendency to disintegrate over the course of 21-26 years.
