Linux Questions
2 replies to this topic
#1 coldone OFFLINE
coldone
  • 1,664 Thanks
  • 1,683 posts
Posted June 16, 2013 - 09:55 PM
I want to switch distros from ubuntu to mint. How do I do that without loosing all my files? I never have been able to get the backup system to work or the free cloud service provided by ubuntu.
#2 lyall OFFLINE
lyall
  • 2,180 Thanks
  • 1,577 posts
Posted June 16, 2013 - 10:33 PM
http://www.garron.me...ns-distros.html
http://www.linuxbsdo...d-ubuntu-10-04/
http://forums.linuxm...p?f=46&t=136424
the above links should help
you can also install mint to a usb memory stick
you can copy your data to a cd/dvd disk or a memory stick - if you want to install Mint only
you should backup your data before you start - to be on the safe side
go the the Mint Linux forums - a lot of good people  there can also help
be safe and think about what you are done
good luck
Edited by lyall, June 16, 2013 - 10:33 PM.
  • coldone said thank you
#3 HDWildBill OFFLINE
  • 8,978 Thanks
Posted June 17, 2013 - 09:47 AM
The way I do it, and I switch quite often, is to copy my entire home directory to an external hard drive the do a complete new install of the new distro then I just copy back the files I want on my new install.  I also have another PC that I use as my test machine and before I install a new distro on my main machine it will be installed on the test box so I have a good idea if I'm going to like it and any issues I may encounter with it.
The latest MintLinux has gotten some good reviews.  Let us know how you like it.
  • lyall and Trav1s have said thanks
