How Can I Tell What A Simplicity I Am Parting Out If It Has No Info
18 replies to this topic
#1 Littledeere OFFLINE
Littledeere
  • 1,664 Thanks
  • 1,490 posts
Posted June 16, 2013 - 08:01 PM
This is just as it sounds guys.I have 2 tractors I have pulled fron the crusher to save a few parts I seen but I would like to know what the tractors are so I 'm not working in the blind here.
I think the one was a tan color win new and has been painted many times
Any help would be great
  • Texas Deere and Horse and boyscout862 have said thanks
#2 New.Canadian.DB.Owner OFFLINE
  • 2,348 Thanks
  • 1,502 posts
Posted June 16, 2013 - 08:30 PM
They look like an early to mid 1960's round hooded 725, Landlord, or Broadmoor.  The Allis equivalents are the B1, B10, Big Ten, etc.  The experts will be here shortly.
  • Littledeere and boyscout862 have said thanks
#3 skunkhome OFFLINE
skunkhome
  • 323 Thanks
  • 455 posts
Posted June 16, 2013 - 09:37 PM
They are not 700 or 725 or B1. They had different dashes (1/4" plate of steel). One or both are either a 9 hp Landlord, 101, 2010 or 2012. If the front wheels are original it is a 2012. It is really hard to tell because the pictures are just so so and can't see the grills. The one with the burnt seat could be an AC early B10, Big Ten, Late B10 or B12. Like with the other if the front wheels are original it may be a B12.
All would have been built between 1964 and 1966. Most parts are going to be interchangeable.
Edited by skunkhome, June 16, 2013 - 09:54 PM.
#4 Texas Deere and Horse ONLINE
  • 14,901 Thanks
  • 15,518 posts
Posted June 16, 2013 - 11:11 PM
Kenny, The one that you think might be tan, is it gold by chance. If so, it's a Simplicity built M/W Squire 9 or 10. Can you get any numbers off the engine? We can get close with the engine numbers.
#5 boyscout862 OFFLINE
  • 13,693 Thanks
  • 9,476 posts
Posted June 17, 2013 - 05:08 AM
The main point on those two that you have is that the same parts were used on a lot of Simplicity and AC GTs. You did a good thing saving them. I would try to build one out ofthe two. There are a many attachments for them around. Check out www.SimpleTractors.com for history, sales brochures and other info. My favorite GTs are Bolens because they are very stong and get work done. My second favorite are the ones like you have there. They are not as strong, as Bolens but, are faster and more fun to play with. Good Luck, Rick
  • Littledeere said thank you
#6 KC9KAS ONLINE
KC9KAS
  • 5,482 Thanks
  • 4,736 posts
Posted June 17, 2013 - 10:01 AM
My thought was an Allis because of the steering wheel.
#7 skunkhome OFFLINE
skunkhome
  • 323 Thanks
  • 455 posts
Posted June 17, 2013 - 07:28 PM
Steering wheels are definately from either species. Allis were originally white with the exception of the B12
#8 Littledeere OFFLINE
Littledeere
  • 1,664 Thanks
  • 1,490 posts
Posted June 17, 2013 - 09:59 PM
That's the problem Brian sel plates are gone or not readable this one tractor must have been painted 20 times but the paint on the bottom looks to be a lite tan color.I hae seen the Wards tractors and I had a early Allis don't look right for them
#9 skunkhome OFFLINE
skunkhome
  • 323 Thanks
  • 455 posts
Posted June 18, 2013 - 07:39 AM
We really need better photos to tell much else. A shot from the grill side could solve the issue. The AC yellow can fade out to a tan looking color under certain conditions.
Edited by skunkhome, June 18, 2013 - 07:42 AM.
#10 acguy96 OFFLINE
acguy96
  • 26 Thanks
  • 44 posts
Posted June 19, 2013 - 04:19 PM
Allis Chalmers had a different style seat than that, but Simplicity had one like that.
Edited by acguy96, June 19, 2013 - 04:20 PM.
#11 skunkhome OFFLINE
skunkhome
  • 323 Thanks
  • 455 posts
Posted June 19, 2013 - 11:33 PM
That I obviously a foreign seat regardless of the make. Looks like a boat seat.
#12 acguy96 OFFLINE
acguy96
  • 26 Thanks
  • 44 posts
Posted June 20, 2013 - 05:37 PM
Those pictures are not of the same tractor. I am talking about the one with the pan seat (first one).
#13 acguy96 OFFLINE
acguy96
  • 26 Thanks
  • 44 posts
Posted June 20, 2013 - 06:07 PM
I looked a little closer at the edge of the grill on the one with the pan seat and it looks to be a simplicity.
Simplicity Grill
Simplicity Grill
Edited by acguy96, June 20, 2013 - 06:07 PM.
#14 simplicityac nut OFFLINE
simplicityac nut
  • 18 Thanks
  • 77 posts
Posted June 22, 2013 - 09:54 PM
Id say there both simplicitys,that mesh grill is a give away for me
#15 skunkhome OFFLINE
skunkhome
  • 323 Thanks
  • 455 posts
Posted June 22, 2013 - 11:11 PM
The early B10 had an expanded metal grill as well but if the front wheels are original than it isn't a B10.
