John Deere 210
4 sale on cl
This topic has been archived. This means that you cannot reply to this topic.
7 replies to this topic
#1 TomLGT195 OFFLINE
TomLGT195
  • 3,086 Thanks
  • 2,384 posts
Posted June 16, 2013 - 03:33 PM
heres a JD 210 on CL in nw CT just posted today
http://nwct.craigsli...3874401424.html
Edited by TomLGT195, June 16, 2013 - 03:34 PM.
#2 johndeereelfman OFFLINE
johndeereelfman
    Elfin Majic
  • 5,576 Thanks
  • 2,562 posts
Posted June 16, 2013 - 03:39 PM
Good price for the condition it's in. I'd make sure that both back rims are the same width, since there is two different width tires on it right now. Good luck to you if you go after it.
#3 Cat385B ONLINE
    Therapy CAT
  • 12,650 Thanks
  • 9,352 posts
Posted June 16, 2013 - 04:23 PM
If it wasn't for the price that these command when parted out, I would say that is over priced. That poor '75 model is hashed.
#4 JDBrian OFFLINE
  • 9,594 Thanks
Posted June 16, 2013 - 04:24 PM
The rear axle/wheels don't look quite right. Perhaps it's just the wheel width as Troy says but I'd look the rear end over very carefully. The steering system can also be expensive to repair on these if it's worn out. Transmission issues are another common problem. Hard to test if it won't run but it should at least go into all gears.
#5 johndeereelfman OFFLINE
johndeereelfman
    Elfin Majic
  • 5,576 Thanks
  • 2,562 posts
Posted June 16, 2013 - 07:00 PM
Guys around here are buying these 200 series tractors left and right and making them pulling tractors. Thus the reason I said the price was right. Since they repower the tractors, they really don't care if the motors run or not, and the transmissions get torn apart no matter if they are good as is or not. For a puller, this is a great price. For the restorer, the price is high, as there would be a lot of work to do.
I went to check it out again, to see what Brian saw, but the listing is no longer there.
#6 olcowhand ONLINE
  • 37,228 Thanks
  • 30,214 posts
Posted June 16, 2013 - 07:14 PM
What were they asking?  Just curious.
#7 Littledeere OFFLINE
Littledeere
  • 1,628 Thanks
  • 1,456 posts
Posted June 16, 2013 - 08:02 PM
It was 150.00 or 175.00 I don't remember witch
#8 TomLGT195 OFFLINE
TomLGT195
  • 3,086 Thanks
  • 2,384 posts
Posted June 17, 2013 - 04:47 PM
its gone as of today (mon)
