Exhaust Mod
11 replies to this topic
#1 willy1094 OFFLINE
willy1094
  • 38 Thanks
  • 72 posts
Posted June 14, 2013 - 01:52 AM
Has anyone done a pratical exhaust run to the rear of the tractor?  I have a '73 Jim dandy and between the deck and the brake rods there is not a lot of room to keep it under the tractor.  I would like to keep it all pipe, no flex tube.  If you have done it and have pictures that would be GREAT!
Thanks
  • larryd said thank you
#2 Ryan313 OFFLINE
  • 3,408 Thanks
  • 5,242 posts
Posted June 14, 2013 - 03:09 PM
Have you ever seen the exhaust systems for the 8N they have at TSC? Every time I see it I always think about getting one to try it.
#3 Dave Central NY OFFLINE
Dave Central NY
  • 106 Thanks
  • 92 posts
Posted June 14, 2013 - 09:00 PM
I have one on a 1978  PK 1614 .  I used the pipe and muffler combination designed for a Massey Ferguson 35 .
Actually quite easy to install  with pipe fittings and  a hanger on the back. As I recall  I had to make an adjustment to the pipe with a big hammer to make it hang straight down from the engine.  It doesn't really make it any quieter especially if you have certain implements mounted on the rear that bounce the sound  right back up to the driver. I think the next one I change I will try a muffler for a Farmall  Cub  or a Farmall A, whichever has the right diameter. A muffler for an Allis Chamlers  B or C might be the right dia also.  Probably try one on the 24/1_  I'm rebuilding.
#4 willy1094 OFFLINE
willy1094
  • 38 Thanks
  • 72 posts
Posted June 15, 2013 - 03:10 AM
I used black pipe to make a stack that looked great but I was deaf by the time I got done mowing.  All I'll really be doing is mowing so how does it sound with nothing back there?  Would I be better off with the exhaust out the front.  I already have the pipe dropped straight down by the bell/flywheel (45 from engine toward the dash and then a 90 straight down) so now I just have to use 45's or 90's to get where I want.  I'll have to check the exhausts out at TSC.
Edited by willy1094, June 15, 2013 - 03:12 AM.
#5 willy1094 OFFLINE
willy1094
  • 38 Thanks
  • 72 posts
Posted June 15, 2013 - 03:17 AM
Would this
444083899
be louder than
023558299
I'm thinking the first may be more compact and maybe the threads will match the pipe threads??
Edited by willy1094, June 15, 2013 - 03:19 AM.
#6 Ryan313 OFFLINE
  • 3,408 Thanks
  • 5,242 posts
Posted June 18, 2013 - 07:27 PM
The first one you posted is very small, and I am pretty sure that muffler has 3/4 threads, and the K series engines have a 1 inch hole.
  • willy1094 said thank you
#7 willy1094 OFFLINE
willy1094
  • 38 Thanks
  • 72 posts
Posted June 19, 2013 - 12:27 AM
Ryan,
Thanks.  I didn't look at the specs since I just did a quick search.  Any opion on putting it low and up front?  I would think I should put it behind the bumper so I do not hit anything.  I'm just looking for the quitest option that is small enough to fit and not get in the way of anything.
Thanks again everyone
#8 Ryan313 OFFLINE
  • 3,408 Thanks
  • 5,242 posts
Posted June 19, 2013 - 05:50 PM
Ryan,
That may work, but I am not sure if it will clear when you have an attachment on it. If I remember correctly your tractor is a Jim Dandy, not a 1612? That would have the channel frame? I am not sure off the top of my head what the mounts on those look like exactly, but I think it will clear.
#9 countryboy88 OFFLINE
countryboy88
  • 105 Thanks
  • 146 posts
Posted June 21, 2013 - 12:48 PM
It belongs to Lovintractorin.
#10 willy1094 OFFLINE
willy1094
  • 38 Thanks
  • 72 posts
Posted June 23, 2013 - 02:02 AM
I'm not sure but that looks like it may get in the way of the deck.  That's pretty much the idea I was looking for.  I'll just have to work out getting everything to fit.  Has he mad any comments on how loud or quiet it is?
Thanks
#11 countryboy88 OFFLINE
countryboy88
  • 105 Thanks
  • 146 posts
Posted June 23, 2013 - 08:42 AM
I'm not sure if he has made any coments about the noise but here are two videos of it.
#12 willy1094 OFFLINE
willy1094
  • 38 Thanks
  • 72 posts
Posted June 24, 2013 - 09:06 AM
Hard to tell since it is a video but that seems pretty quiet!  Thanks a lot.
