Cooling Fan For Hydro Trans, Massey Model 14 Needed
7 replies to this topic
#1 oxen OFFLINE
oxen
  • 1 Thanks
  • 2 posts
Posted June 13, 2013 - 05:23 PM
I am looking for a cooling fan for the hydro I have a massy model 14 I need one badly cant mow my lawn can call Eric @ 814 3684867
thanks
  • IamSherwood said thank you
#2 Bolens 1000 OFFLINE
  • 14,903 Thanks
  • 18,103 posts
Posted June 13, 2013 - 05:29 PM
Welcome to GTT
You may want to try one of our site sponsors to see if they have any.
  • oxen said thank you
#3 Ron White OFFLINE
Ron White
  • 124 Thanks
  • 124 posts
Posted June 13, 2013 - 05:39 PM
Do you have a part number, would this one work ??
http://www.ebay.com/...=item35c009b506
#4 OkieGt OFFLINE
OkieGt
  • 1,428 Thanks
  • 1,447 posts
Posted June 13, 2013 - 05:55 PM
Go to any appliance repair shop and get a 5" plastic cooling fan from a GE fridge or freezer, you will have to enlarge the center hole, but that's easy, I drill it a little small then heat the shaft with a torch and slide it on. They cost about 5 bucks at the AP store.
Edited by OkieGt, June 13, 2013 - 05:56 PM.
#5 olcowhand OFFLINE
  • 40,365 Thanks
  • 31,175 posts
Posted June 13, 2013 - 05:56 PM
Go ahead & now the lawn.  The MF14 has a Sundstrand hydro with no cooling fins on the hydro unit, so the fan does little for cooling anyway.  Best thing is to add a small cooler of some sort.  The small power steering cooling units on some auto's would do fine even without a fan blowing on them.
#6 IamSherwood OFFLINE
  • 8,390 Thanks
Posted June 13, 2013 - 06:26 PM
Chances are, you won't find a new one, and any older used one you get, probably
won't last long. Good suggestion from OkieGT, or as Olcowhand said, just go
cut the grass without it.
Cutting the tall grass, will put more strain/load on the deck/engine, than the
hydro. Different story, if you where pushing, or pulling a heavy load.
Oh yeah, Welcome to GTT. :wave:
Nice to have another Massey around.
We'd sure like to see some pics of your MF, when you get a chance.
#7 OkieGt OFFLINE
OkieGt
  • 1,428 Thanks
  • 1,447 posts
Posted June 13, 2013 - 07:05 PM
A friend of mine saw my Massey MF14 fan and he works on appliances and said it looked like a freezer/fridge fan, sur enough we matched up to one exactly like it except the shaft size and that was easy to change
#8 oxen OFFLINE
oxen
  • 1 Thanks
  • 2 posts
Posted June 20, 2013 - 06:00 PM
REF NO 31    PART NO  526  543  M91
