Mf 12 Pump Shaft & Seal
3 replies to this topic
#1 Sawdust OFFLINE
Sawdust
  • 5,656 Thanks
  • 3,368 posts
Posted June 13, 2013 - 02:41 PM
The last time I used my GT I had severe fluid leakage around the seal at the pump shaft. If you read in my http://gardentractor...f-12-rebirthed/ post I mentioned I'm certain this is caused by nicks in the shaft. The PO had problems replacing this seal & nicked the shaft. My question is this shaft available. I did some browsing & everything asks what series pump this is. It is a MF12 with Hydrostatic model # 902050 Serial # 01-HA 34905. When I first bought it after a few weeks of using I removed the shaft, emery clothed & polished the best I could then replaced the seal...still leaked. Another thought can pressure build up in this pump housing to force fluid leakage out the seal? Any response is appreciated. Thanks
Jim
#2 bschenk OFFLINE
bschenk
  • 27 Thanks
  • 10 posts
Posted June 13, 2013 - 03:44 PM
if you measure the diameter of shaft you get a thin sleeve to go over it and a new seal. I think it is called speedi-sleeve. any good auto parts can get them.
Edited by bschenk, June 13, 2013 - 03:47 PM.
  • Sawdust said thank you
#3 New.Canadian.DB.Owner OFFLINE
  • 2,331 Thanks
  • 1,498 posts
Posted June 13, 2013 - 07:46 PM
Here is a primer on Speedi-Sleeves by SKF.  Timkin makes a version called Redi-Sleeve.
#4 Sawdust OFFLINE
Sawdust
  • 5,656 Thanks
  • 3,368 posts
Posted June 15, 2013 - 08:37 PM
That's a great idea guys I did some research on those & I think I will try that. I will be taking the shaft out to do this. Thanks!
