Wheel Horse Rim/tire Question
3 replies to this topic
#1 farmer john OFFLINE
farmer john
  • 1,762 Thanks
  • 895 posts
Posted June 13, 2013 - 01:46 AM
Hi all, i really like the look of bar tires on gts and was thinking of putting some on my wh 416, it has 23-10-12 on it now but i like the look of the 23-12-12, would they fit on the stock rim or make the tire taller and look out of place? and if i need bigger rims where do i get them? i love the chrome and polished aluminum ones, thanks for any info
#2 hamman OFFLINE
hamman
    Homelite Owner Extraordinaire
  • 6,360 Thanks
  • 2,837 posts
Posted June 13, 2013 - 07:52 AM
Not sure about fitting. You can check with Miller Tire in Ohio for tires and I've heard that places that customize and sell parts for golf carts can get the wheels. Good Luck.
  • farmer john said thank you
#3 twostep OFFLINE
twostep
    Rockstar
  • 1,970 Thanks
  • 2,528 posts
Posted June 13, 2013 - 09:17 AM
Putting a 12" tire on a 10" rim is not a problem... but you need to make sure the tire won't rub on anything.
  • hamman and farmer john have said thanks
#4 Canawler OFFLINE
Canawler
  • 1,948 Thanks
  • 1,801 posts
Posted June 13, 2013 - 01:53 PM
The current wheel for the 10.5" tire is probably 8.5" wide.  Usually 12" wide tires would mount on a 10.5" wheel.
As far as I know, there isn't a 23x12.00-12 tire.  To get a 12" wide tire you have to jump up to a 26x12.00-12.  I'm not a WH guy so someone else will have to comment on whether a 26x12.00 will actually fit your tractor.
