New Massey 12
47 replies to this topic
#31 LYON222 OFFLINE
LYON222
  • 134 Thanks
  • 115 posts
Posted June 14, 2013 - 07:51 PM
Noe no tank under the seat. I'm going out in the shop to look at some things now. Everyone has been a great help so far, thank you all!
  • chris m said thank you
#32 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted June 14, 2013 - 07:58 PM
These guys are great aren't they.
Always there to help. :thumbs:
  • chris m and LYON222 have said thanks
#33 LYON222 OFFLINE
LYON222
  • 134 Thanks
  • 115 posts
Posted June 14, 2013 - 08:12 PM
Okay I went out and looked no dip stick I could see. ImageUploadedByTapatalk 21371258745.922894.jpg
#34 chiefgoodman OFFLINE
chiefgoodman
  • 36 Thanks
  • 123 posts
Posted June 14, 2013 - 08:20 PM
Congrats on the find and getting her running. Where are you located LYON?
  • LYON222 said thank you
#35 chris m OFFLINE
chris m
  • 3350 Thanks
  • 4069 posts
Posted June 14, 2013 - 08:21 PM
That is how mine looks also. I am not sure yet about where on the end of the tube is considered full. I would think that as long as the fluid is on any part of the tube, that it would be ok? Maybe one of the other MF 12H owners could tell us for sure.
Mine is apart waiting for the restore to start, so I haven't checked into this part of it yet.
#36 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted June 14, 2013 - 08:42 PM
I'd say, fill it to the top.
As far as I know, that's the same hydro as the MF12s, with the tank
under the seat. So, make sure it's full, and if you want to, find a
tank to put under the seat, and fill it even more.
That's what I did on mine 3 years ago.
#37 chris m OFFLINE
chris m
  • 3350 Thanks
  • 4069 posts
Posted June 14, 2013 - 08:48 PM
I'll have to look into that thanks Will! I would guess that you would just eliminate the vent tube and use this location to tie in the new holding tank?
#38 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted June 14, 2013 - 08:53 PM
Yes, that's what I did. I'm looking to see if I have any pics.
If I recall, it's a pipe thread, where the vent tube screws into.
I did have to torch away a bit of the frame, to make room for the hose, but not enough to
make a structural difference.
#39 LYON222 OFFLINE
LYON222
  • 134 Thanks
  • 115 posts
Posted June 14, 2013 - 09:01 PM
I can see there being a tank under the seat at one time, the "cap" or what is under the seat for the hydro, looks like a small hose would push right on.
#40 LYON222 OFFLINE
LYON222
  • 134 Thanks
  • 115 posts
Posted June 14, 2013 - 09:02 PM
im located in mt.bethel pa, right near bangor
#41 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted June 14, 2013 - 09:03 PM
Nope, only pics I've got, don't show much detail.
Before.
After. You can just see where I ran the hose.
#42 HowardsMF155 OFFLINE
  • 3079 Thanks
  • 3084 posts
Posted June 14, 2013 - 09:59 PM
As long as fluid is below the slit, air can still move in and out of the transmission when it heats up in use.  I've filled mine way up before, then when I ran the trans for an extended period, the excess fluid ran out of the tube and left a trail behind me.  I'm going to try and find a small tank to use as an overflow tank myself one day.
#43 chris m OFFLINE
chris m
  • 3350 Thanks
  • 4069 posts
Posted June 14, 2013 - 10:10 PM
That "cap" you see under the seat is the vent for the Peerless trans axle. The Hydro and the Trans axle are 2 separate units. Hydro takes transmission fluid, and the trans axle takes gear oil. I just figured I would mention this as I have seen people make the mistake of adding the wrong fluid to either unit.
#44 HowardsMF155 OFFLINE
  • 3079 Thanks
  • 3084 posts
Posted June 14, 2013 - 10:14 PM
Guilty!!
#45 chris m OFFLINE
chris m
  • 3350 Thanks
  • 4069 posts
Posted June 14, 2013 - 10:21 PM
Guilty!!
LOL! I would have been to if I had not read about that before getting mine! :D
