Mf14/16 Hydro Shifter Brake
8 replies to this topic
#1 DH1 OFFLINE
DH1
    Electric Tractors
  • 5495 Thanks
  • 5633 posts
Posted June 12, 2013 - 07:58 PM
Looking for some info on my MF16s hydro control handle, problem is that it's too loose, doesn't hold position.
This is what it's suppose to look like
This is what I got, notice the top part has no liner on it, has some kind of bushing someone put in to add some friction.
What is that lining they put on the top part, AGCO parts books show it on the "Clamp assembly Shift lever brake"?
To me looks like a brake lining glued on.
Where do you get this?
How thick should it be?
What kind of glue do you use?
#2 OkieGt OFFLINE
OkieGt
  • 1434 Thanks
  • 1447 posts
Posted June 12, 2013 - 09:01 PM
Your probably going to have to fabricate the material, maybe cub brake ling material, or a bake-o-lite type material. I believe is fairly easy to get. Your tractor has been the victim of a self-taught engineer, I'm so very sorry, It's probably going to get worse the more you look, again sorry. I have never seen one worn like that, it makes me cringe to think what the PO did to that poor machine. I'll loan you my shovel if you know where to find him, lol
#3 DH1 OFFLINE
DH1
    Electric Tractors
  • 5495 Thanks
  • 5633 posts
Posted June 21, 2013 - 08:09 PM
Bump
Anybody know where to get this friction material of something that would work and how to attach it?
#4 olcowhand OFFLINE
  • 44095 Thanks
  • 32301 posts
Posted June 21, 2013 - 08:58 PM
Bump
If I don't forget, I'll look at my old MF14 carcass to see if that part still has a good lining (I'm thinking it's fine).  If it's still good, it's yours!
  • IamSherwood said thank you
#5 DH1 OFFLINE
DH1
    Electric Tractors
  • 5495 Thanks
  • 5633 posts
Posted June 22, 2013 - 07:55 PM
Would this work?
https://www.bantasaw...ct.asp?i=&p=482
#6 olcowhand OFFLINE
  • 44095 Thanks
  • 32301 posts
Posted June 22, 2013 - 08:34 PM
Just went & looked at the old MF14 carcass, and the lining is gone, sorry.  Just rivets sticking up.
  • DH1 said thank you
#7 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted June 23, 2013 - 05:40 AM
May you could find some brake lining at a nearby scrapyard.
#8 olcowhand OFFLINE
  • 44095 Thanks
  • 32301 posts
Posted June 23, 2013 - 07:52 AM
Yeah, I was thinking the same.  Look for something with a driveshaft brake band, like on older larger trucks.
#9 DH1 OFFLINE
DH1
    Electric Tractors
  • 5495 Thanks
  • 5633 posts
Posted July 15, 2013 - 09:05 PM
I was able to fix this by using the one top part I have with the liner on it, I bent it slightly near the end where the hole is to try to tighten the gap a bit and it worked.
Hydro control lever has resistance from full reverse to full forward.
Bent the top part just to the left of my finger.
Also ground away some of the liner at the extreme left where it is touching the bottom part stopping it from closing more.
Edited by DH1, July 15, 2013 - 09:08 PM.
