My First Case
8 replies to this topic
#1 Bob IN OFFLINE
Bob IN
  • 1,477 Thanks
  • 676 posts
Posted June 12, 2013 - 01:42 PM
Well here is my first case. I got a snow blower, wheel weights, and chains included. I am having a bit of trouble with the mower clutch. It wont always engage or disengage. Why is this?
  • dropped82, Dieselcubmike and JRJ have said thanks
#2 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted June 12, 2013 - 02:29 PM
Nice solid Case! About the clutch, often there can be a problem with the switch or with the connections at the clutch itself. I'm not familiar with the Case tractors but some clutches have an adjustment on the gap. If the gap is too wide it may not pull in. You could also have a worn out clutch or a coil that is failing. I'd try checking all the connections first. Someone who has experience with the Case clutch will probably be along soon to help out.
#3 83MALIBU OFFLINE
83MALIBU
  • 40 Thanks
  • 69 posts
Posted June 12, 2013 - 03:14 PM
Looks like a nice addition to your collection.
#4 John@Reliable OFFLINE
John@Reliable
  • 1,298 Thanks
  • 1,416 posts
Posted June 12, 2013 - 03:40 PM
Bob, you need to download the manual per serial # of tractor, adjustment of clutch is in it. You either have a EZ adjust or shims.
One thing most "new" case owners have to get use to is it takes a good push to engage the clutch. Also the proper tension on spring on the mule drive is important too.
P.S. I can't stress enough the important of getting the right manuals per serial # of tractor, many changes within same model #'s
#5 John@Reliable OFFLINE
John@Reliable
  • 1,298 Thanks
  • 1,416 posts
Posted June 12, 2013 - 03:43 PM
Brian, most Case / Ingersoll tractors have a manual clutch, not 12v. :thumbs:
  • JDBrian and Arti have said thanks
#6 Arti ONLINE
Arti
  • 1,371 Thanks
  • 995 posts
  • Location: South West Wisconsin . Now in North Central Mo.
Posted June 12, 2013 - 04:02 PM
Congrats on the Case. I think you will find it a real work horse.
Also ditto on John@reliable the manuals are your friend.
#7 dropped82 ONLINE
dropped82
    Nut Case
  • 2,738 Thanks
  • 1,902 posts
Posted June 12, 2013 - 04:10 PM
Be careful Bob. These things are addicting. I also think they reproduce. Mine seem to multiply and I think they are burying my John Deere's. They are great work horses. The hydraulic system is about the strongest you can find on a GT. You don't need extra pumps to run accessories like a loader. Enjoy!
Eric
Sent from my XT897 using Tapatalk 2
#8 dropped82 ONLINE
dropped82
    Nut Case
  • 2,738 Thanks
  • 1,902 posts
Posted June 12, 2013 - 04:13 PM
Also on the PTO's. I'm still learning about mine. They do need adjusted due to wear. Its a pretty simple setup. I have manuals for both types now and will scan them here soon to post up if they are needed.
Eric
#9 KC9KAS OFFLINE
KC9KAS
  • 5,460 Thanks
  • 4,719 posts
Posted June 12, 2013 - 04:47 PM
Very nice looking tractor.
