Weed-Eaters. Let's See 'em
31 replies to this topic
#16 SearsYellow ONLINE
SearsYellow
    Mower Extraordinaire
  • 495 Thanks
  • 594 posts
Posted April 21, 2014 - 05:33 PM
ECHO SRM225
Edited by SearsYellow, April 21, 2014 - 05:33 PM.
#17 Guest_rdehli_*
Guest_rdehli_*
  • Guests
Posted May 01, 2014 - 07:41 PM
I too got sick and tired of cheap trimmers from real mart.   Last summer bought a mid priced stihl it has twice the power of anything that I have ever owned.
  • Gabriel said thank you
#18 richwoodrocket OFFLINE
richwoodrocket
    16 year old JD lover
  • 147 Thanks
  • 177 posts
Posted August 21, 2014 - 03:52 PM
Edited by richwoodrocket, August 21, 2014 - 03:53 PM.
#19 Tennblue59 OFFLINE
Tennblue59
  • 451 Thanks
  • 522 posts
Posted January 01, 2015 - 07:37 PM
I use Stihl equipment - little more money up front, but last forever and you can get parts if you need them.
Echo is debatably the #2 pro trimmer behind Stihl. A "pro" quality trimmer is definitely worth buying, especially if you have a larger yard or acreage to deal with. Lots more power than a box store disposable one, and usually can be adapted to brush blades for heavier growth.
I use a Stihl FS85 (2 stroke) for yard work, and an FS90 (4 mix - hybrid 4 stroke/2stroke motor) for brush cutting, But presently rebuilding an FS250 (2 stroke) for heavy brush cutting duties and clearing saplings/heavy growth. The 250 packs 2.15 hp, and with a saw blade, can cut small trees!
  • Sawdust said thank you
#20 NUTNDUN OFFLINE
  • 10,339 Thanks
Posted January 01, 2015 - 07:44 PM
We have a Stihl FS90 as well and it does a great job. I gotta admit it is weird using a 4 stroke trimmer because of it being thumpier but Stihl did a good job with the vibration dampening and balancing.
#21 adamjd200 OFFLINE
adamjd200
  • 2,046 Thanks
  • 2,173 posts
Posted January 01, 2015 - 10:31 PM
No pics as they are currently buried in the garage but, I have a Homelite, a Stihl, and a Robin, as well as two Homelites waiting to be repaired.  I also have a Echo brush cutter for tough jobs.
#22 OldBuzzard OFFLINE
OldBuzzard
  • 7,018 Thanks
  • 4,790 posts
Posted January 02, 2015 - 06:41 PM
Haven't put it together yet, as I'm not sure what tractor I want to put it on.
Bolens 12v tractor mounted trimmer:
#23 UncleWillie OFFLINE
  • 15,660 Thanks
  • 8,758 posts
Posted January 02, 2015 - 07:42 PM
You can put it on the Buzzard!
#24 sodisr ONLINE
sodisr
  • 663 Thanks
  • 773 posts
Posted January 06, 2015 - 10:46 AM
I thought that was a fertilizer spreader... :dancingbanana:
#25 UncleWillie OFFLINE
  • 15,660 Thanks
  • 8,758 posts
Posted January 06, 2015 - 02:37 PM
It trims and spreads at the same time.
  • sodisr said thank you
#26 Bill 76 ONLINE
Bill 76
  • 1,930 Thanks
  • 1,189 posts
Posted January 07, 2015 - 03:18 AM
Don't have one. FIL gave me some cheap of junk that took 10 min to start , took me 10 seconds to toss it in the scrap heap.
But I did use the 2 stroke gas to do edging under the chain link fence--lasted all summer.
#27 crittersf1 ONLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted January 09, 2015 - 09:32 AM
  • KennyP and Sawdust have said thanks
#28 bbuckler OFFLINE
bbuckler
  • 3,422 Thanks
  • 3,043 posts
Posted January 09, 2015 - 09:40 AM
#29 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 9,855 Thanks
  • 5,950 posts
Posted January 09, 2015 - 12:12 PM
I have a weedeater brand thing. Smallest they sell and cheapest. Bought it in 2006 and it's be running with no problems since. The only thing I do to it is add fuel and string. Never changed the plug never cleaned the air filter never drained the fuel. Never fails to start even after hanging in the unheated garage all winter.
My yard at both houses I used it at require very little trimming. My yard now I don't even have to use a push mower it's set up so everything can be mowed with the tractor. The only thing I have to do is weedeater around the house and garage.
Edited by toomanytoys84, January 09, 2015 - 12:14 PM.
  • KennyP and bbuckler have said thanks
#30 bbuckler ONLINE
bbuckler
  • 3,422 Thanks
  • 3,043 posts
Posted January 09, 2015 - 12:45 PM
That what I use they are cheap enough to throw away after they stop running and buy another . I had a high dollar one lasted maybe 2 years stopped running and I could never get that fixed right.
