Caroll Stream Diesel Options
20 replies to this topic
#1 Trav1s ONLINE
Trav1s
  • 3,655 Thanks
  • 4,606 posts
Posted June 12, 2013 - 11:13 AM
10 HP single with more torque than a 13-15 HP gas
http://www.ebay.com/...=item27bcdc0ddd
20 HP diesel v twin available in 1" and 1 & 1/8" crank sizes
 1" - http://www.ebay.com/...=item2a2d6ffab0
1&1/8" - http://www.ebay.com/...=item2a2d6ffa9a
I am thinking the 10 HP single might be a good option for a 314...
  • Utah Smitty, boyscout862, chaentjens and 1 other said thanks
#2 twostep ONLINE
twostep
    Rockstar
  • 1,990 Thanks
  • 2,541 posts
Posted June 12, 2013 - 11:34 AM
Is the 314's kohler shot?
#3 NUTNDUN OFFLINE
  • 10,354 Thanks
Posted June 12, 2013 - 11:43 AM
There were at least two tractors up at plow day this year with the single cylinder diesels. They ran good and had plenty of power. Was pretty cool seeing them blow some black out when loaded. I would like to do one of the diesels at some point. I think the 10hp would be the easiest fit in place of the Kohler.
#4 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 14,338 Thanks
  • 10,295 posts
Posted June 12, 2013 - 12:36 PM
What's the formula for figuring torque? How does less hp have more torque???
#5 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted June 12, 2013 - 12:39 PM
Travis: Take a good look at the Spec's on that 20hp engine. I think you have to convert from metric to inches?
But I think you will find that it is enough Physically bigger than the original engine(I was daydreaming about one in a small Bobcat)  you would have to make extensive modifications to accomodate it. There would be a big WOW Factor in having the 20HP diesel.
But I doubt it would be worth all the extra work?
Where the 10 Hp will be much easier to fit in the 314..
I think you will find the 10hp more than adequate.
Edited by JD DANNELS, June 12, 2013 - 12:44 PM.
  • Trav1s said thank you
#6 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted June 12, 2013 - 12:58 PM
I forget where I was looking at but I know they make diesel conversion kits for the vtwin motors. Kohler and briggs sell diesel motors just by themselves.
#7 Trav1s ONLINE
Trav1s
  • 3,655 Thanks
  • 4,606 posts
Posted June 12, 2013 - 02:14 PM
No, just thinking of a repower because I can... :smilewink: and I do likes me the smell of some diesel exhaust in the morning. :thumbs:
Edited by Trav1s, June 12, 2013 - 02:36 PM.
  • Cvans and twostep have said thanks
#8 Trav1s ONLINE
Trav1s
  • 3,655 Thanks
  • 4,606 posts
Posted June 12, 2013 - 02:31 PM
Diesels have a higher compression which yields higher torque.  If two identical engines are built except for compression ratio, the higher compression will yeild more torque.  This is a simple summary but helps get the picture.
Did some conversion the max torque is right at 20 ft/lb using this converter below:
http://www.convertun...m/kg m/to/lb ft
The k321 in optimal condition is 14 HP but I cannot find the torque rating.  I will work on that a bit more...
#9 JDBrian OFFLINE
  • 9,655 Thanks
  • 14,162 posts
Posted June 12, 2013 - 02:32 PM
If this is a 314 JD then I don't think it will fit. I looked into that option and the crank is about 7" from the mounting surface. This is much higher than the crank on the K321 which has the oil pan below the mounting flanges. You may get it to work if you went to a driveshaft and u joints like a 317 but with the stock drive shaft setup the crank needs to line up with the hydro input shaft.
  • Trav1s and twostep have said thanks
#10 Trav1s ONLINE
Trav1s
  • 3,655 Thanks
  • 4,606 posts
Posted June 12, 2013 - 02:35 PM
I was going to convert the metic measurements on their site to standard and go from there.  It is a shame I like to tinker with things and don't leave well enough alone.
  • twostep said thank you
#11 JDBrian OFFLINE
  • 9,655 Thanks
  • 14,162 posts
Posted June 12, 2013 - 02:41 PM
My K321 has a cracked block. It still runs but a little rough and doesn't even smoke much. It pushes oil out though the crack so I've been looking at replacement engines. It's almost impossible to find a Kohler K321 here. The other issue with the 10hp clones is that you would need to make an adapter to get power off the flywheel side of the crank. There is a starter cup mounted to the flywheel so those holes could be used for an adapter but I don't know how strong that setup would be. The 20hp vtwin may actually have a lower crank height than the 10hp single!
#12 ghack OFFLINE
ghack
  • 29 Thanks
  • 35 posts
Posted June 12, 2013 - 06:42 PM
Diesel fuel has almost twice the btu per gallon than gas. but requires hi comp to run. so you get better fuel economy and more power. love diesels. would like to find a cheap 16 -20 for one of mine.
#13 Trav1s ONLINE
Trav1s
  • 3,655 Thanks
  • 4,606 posts
Posted June 13, 2013 - 09:43 AM
Been playing around a bit this morning with specs:
CROSS REFRENCE TO:
HONDA
  • Gx270
  • Gx340
  • Gx390
 KOHLER
  • CS8.5T
  • CS10T
  • CS12T
BRIGGS & STRATTON
  • 185432-0247
  • 201432-0035
  • 245432-0247
More in a bit...
#14 Trav1s ONLINE
Trav1s
  • 3,655 Thanks
  • 4,606 posts
Posted June 13, 2013 - 11:30 AM
Founds specs/dimensions on the Honda gx340
Length (min) 407 mm (16.0")
Width (min) 485 mm (19.1")
Height (min) 449 mm (17.7")
Crank centerline = 133.5 mm (5.26")
gx390 is similar http://engine.honda..../specifications
Brian, do you have the Kohler info handy?
Edited by Trav1s, June 13, 2013 - 11:38 AM.
#15 twostep ONLINE
twostep
    Rockstar
  • 1,990 Thanks
  • 2,541 posts
Posted June 13, 2013 - 11:39 AM
More in a bit...
wow, that shows fuel consumption is lowest at 2700 rpm. that makes me wonder about my diesel.
