Bolens H16 Front Axle Spindle
4 replies to this topic
#1 OkieGt OFFLINE
OkieGt
  • 1434 Thanks
  • 1447 posts
Posted June 11, 2013 - 11:30 PM
I saw a front spindle for a Bolens 850,1000 tube frame with a hole drilled through it for a roll pin, my H16 has a roll pin to hold the wheel on as well, but the manual says it should be a locking collar, any idea why????
#2 chris m OFFLINE
chris m
  • 3350 Thanks
  • 4069 posts
Posted June 11, 2013 - 11:37 PM
Does it look like it is original? Or was a PO a self taught Mechanical engineer? :D
#3 OkieGt OFFLINE
OkieGt
  • 1434 Thanks
  • 1447 posts
Posted June 12, 2013 - 06:31 AM
It looks original, but it cant be. I dont believe the guy drilled them, either this is a early H16 that had them or someone replaces the spindles with older model ones
#4 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted June 12, 2013 - 06:44 AM
To the best of my knowledge they never has roll pins as stock equipment in any tubeframe.
They were supposed to have a locking collar with a set screw type bolt.
  • OkieGt said thank you
#5 OkieGt OFFLINE
OkieGt
  • 1434 Thanks
  • 1447 posts
Posted June 12, 2013 - 06:48 AM
On ebay they have a set from prayters parts listed as Bolens 850 tube frame spindles that use roll pins
http://www.ebay.com/...984.m1423.l2649
I checked the manuals, couldn't find either, but Prayters says this model Bolens 850 is a 191-01 and the manual here is for a 191-02
Edited by OkieGt, June 12, 2013 - 07:01 AM.
