Making A New Blade For A 42" Sears Dozer/snow Plow
10 replies to this topic
#1 chris m OFFLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted June 11, 2013 - 08:33 PM
I spent the day working on making a new blade for my Dads Custom 10XL, The blade that came with it is small and it doesn't angle. This blade (1st picture) I have had for awhile and didn't know what Sears GT it went to, plus it was rusted out. But after looking at the mounts I noticed it is for a Sears custom. So I decided to resurrect it for Dad. I just got done rebuilding the mower deck, I'll post on that another time.
First I had to remove the old rusted blade. That was fun! Man there must have been 80 spot welds lol. I popped them all off with multiple pry bars, as I was trying to not make a lot of noise (people were sleeping)
Next I cut my new piece (15 1/2" x 42") This old Milwaukee cut through this like it was butter, I was going to use the Plasma torch but decided to try this 1st. This is 1/16" thick.
Next I decided to form the blade in my little hydraulic press. It worked great for this!
Here it is clamped in place, and a shot of the old and new blade.
This is were I left off for tonight. Next it will be primer and paint on the frame before I spot weld this together.
  • Alc, hamman, iron Mike and 5 others have said thanks
#2 hamman OFFLINE
hamman
    Homelite Owner Extraordinaire
  • 6,616 Thanks
  • 2,913 posts
Posted June 11, 2013 - 09:07 PM
NIce job.! Should last a long time.
  • chris m said thank you
#3 Utah Smitty OFFLINE
Utah Smitty
  • 1,713 Thanks
  • 1,793 posts
Posted June 11, 2013 - 09:53 PM
That's a good idea to use your press to initially form the blade into the frame.  I have a similar dozer blade for my SS16... it needs a new moldboard (edge the cutting blade bolts to) as a PO ran it too long before changing the blade.  It shouldn't be too hard, though.
Utah Smitty
#4 chris m OFFLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted June 11, 2013 - 10:03 PM
Utah Smitty
I was going to make a wooden cradle to help in the forming process, but I decided just to try this. It worked better than I thought! No creases either. Good luck on yours, It should go fairly well for you. The hardest part is dealing with all the spot welds, they average 1-2" apart on all three rails.
#5 GT5k6spd OFFLINE
GT5k6spd
  • 37 Thanks
  • 53 posts
Posted June 11, 2013 - 11:13 PM
attachicon.gifPICT1366.JPG attachicon.gifPICT1367.JPG attachicon.gifPICT1369.JPG attachicon.gifPICT1370.JPG
attachicon.gifPICT1372.JPG attachicon.gifPICT1374.JPG attachicon.gifPICT1373.JPG attachicon.gifPICT1375.JPG
awesome.    ...i need more toys.
  • iron Mike said thank you
#6 MH81 OFFLINE
  • 29,979 Thanks
Posted June 12, 2013 - 07:09 AM
Nice job Chris. Looks like it'll last many more years.
While you have it all apart, look into dealing with any massive pivot slop or worn holes. The frames are built well, but no one seemed to ever oil any of them in all that mechanism. They tend to get a little loosey goosey.
#7 Utah Smitty OFFLINE
Utah Smitty
  • 1,713 Thanks
  • 1,793 posts
Posted June 12, 2013 - 02:25 PM
I have that problem on a Sears Dozer Blade--lots's of pivot holes that are egged out.  What's the best way to repair them--just weld 'em shut and then redrill?
I've been tempted, but I wasn't sure I could get the hole in the correct place if I did...
Utah Smitty
#8 chris m OFFLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted June 12, 2013 - 02:36 PM
Utah Smitty
You could drill them larger and install a bushing. The one I am working on right now has bushings already.
  • MH81 and Utah Smitty have said thanks
#9 Golden Hurricane OFFLINE
Golden Hurricane
  • 16 Thanks
  • 24 posts
Posted June 14, 2013 - 10:57 AM
This thread was very interesting to me! GT5 put together the photos in a manner that was very easy to navigate & that was swell of him to do that for us! The whole project was well done by Chris M...in Rhode Island...thanks to each of you from a newbie!
#10 chris m OFFLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted June 14, 2013 - 10:39 PM
Well I got the blade welded to it's frame. now I am just working on the lift frame getting it ready for paint.
I also need to pick up a piece of flat stock to make the wear bar.
And the before picture :D
  • GT5k6spd said thank you
#11 MH81 OFFLINE
  • 29,979 Thanks
Posted June 17, 2013 - 07:35 AM
Chris, I'm not saying it was rusted out, but in that picture... I can tell your front wheels are 1% off on toe in. :poke:
Excellent job, great looking build.
