What Would Be A Good Motor To Repower My Mf10
22 replies to this topic
#16 OkieGt OFFLINE
OkieGt
  • 1434 Thanks
  • 1447 posts
Posted June 12, 2013 - 06:18 PM
My buddy picked up a Sears 14 with a spare motor both OH140 motors ran good for 75.00 and somebody came along and offered him 4000.0 bot both and he took it, he's kicking himself now.
#17 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted June 12, 2013 - 06:37 PM
was wondering if by chance i wanted to repower my massey 10  or upgrade power what would be a suitable motor i was thinkin hp range from 12 and up preferably around a 16 to 18 hp but dont know if it would tuck in under hood or not I have a 10 hp tecumseh on it but it starts good but smokes quite abit and on the hils in my yard doesnt quite have the ump id like it to have
just trying to get some ideas an input on it
It's probably already been said, but if I where you, I would pull the head off
your HH100, and see how bad the rings/bore are.
You might get away, with just putting new rings in.
Those Tecumseh engines have plenty enough power, to pull your tractor
up a hill, unless, of course, you're trying to pull a whale behind you.
  • OkieGt said thank you
#18 OkieGt OFFLINE
OkieGt
  • 1434 Thanks
  • 1447 posts
Posted June 12, 2013 - 06:47 PM
"Those Tecumseh engines have plenty enough power, to pull your tractor
up a hill, unless, of course, you're trying to pull a whale behind you"
Sounds like you have had some experience, lol
#19 randmgraham OFFLINE
randmgraham
  • 4 Thanks
  • 27 posts
Posted July 04, 2013 - 11:18 AM
thank you for the info  im just thinking about rebuilding the old indian  that way it has orginal motor it smokes alot so i know rings are bad and it starts too easy  to get rid of it  my strater went out of it a few months ago so i have been using a rope to pull start it an either 1 or 2 pulls on rope and its a running
#20 oliver2655 OFFLINE
oliver2655
  • 37 Thanks
  • 82 posts
Posted July 04, 2013 - 12:42 PM
yes just like everyone else has said definately use a kohler k-series engine!!! never seem to have power issues and its easy to find parts for them. if you dont prefer kohler you could also try a wisconsin. i find those motors to have quite a bit of power too!
#21 randmgraham OFFLINE
randmgraham
  • 4 Thanks
  • 27 posts
Posted August 03, 2013 - 08:38 PM
i think i have decided to rebuild my tecumseh 100  i know what size id like to put on there but then id have to extend the frame a little and hood  i see kohler has a 40 hp motor out and that be sweet but alot of work to do but im just gonna stick with my 10hp
#22 OkieGt OFFLINE
OkieGt
  • 1434 Thanks
  • 1447 posts
Posted August 03, 2013 - 09:24 PM
The problem your going to have is, it will be very hard to find a set of +.10 or +.20 piston and rings, suppliers no longer have both the ring and piston set. they have.+.10 pistons, but not rings, they have +.20 rings, but not pistons. you should be able to get either a standard rod, or -.10, but I believe they are HIGH. try ebay for a NOS set of rings, piston, and rod.
#23 Kalder OFFLINE
Kalder
  • 9 Thanks
  • 13 posts
Posted August 11, 2013 - 01:50 PM
I'm currently swapping a yanmar clone into mine. The HH100 fires with ether, but the carburetor and starter/alternator is missing. The diesel is a tight fit, but it should work. I had to get a 2 inch longer crank to variable shiv belt. And I'm building an intake and exhaust to clear the hood (I don't want to chop up the hood). I'm doing my best to not modify the tractor for this swap. This engine NEEDS a stack, it smokes a little, and it burns my eyes!
Edited by Kalder, August 11, 2013 - 01:55 PM.
