I Hate My Truck Please Help
42 replies to this topic
#31 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 11,033 Thanks
  • 5,984 posts
Posted June 11, 2013 - 11:15 AM
Those 300 sixes were hard to break for sure..  When they go it's most always #1 rod & crank problems as that one is last in the oil 'food-chain'..  **Maybe throw a AC Delco coil on it??  LOL  So the coil's + terminal should have 12V + when the key is on.  The neg - terminal gets powered intermittently via the signals from the distributor & the ignition box..  Usually if a box goes-  It doesn't work at all..  I could dig out the old Chiltons & look if you like..
#32 DougT ONLINE
DougT
    Dog Approved
  • 7,077 Thanks
  • 5,062 posts
Posted June 11, 2013 - 11:22 AM
Those coils usually have a capacitor for radio suppression mounted on them. maybe try unplugging it if its still in the system.
#33 916 hydro OFFLINE
916 hydro
  • 114 Thanks
  • 139 posts
Posted June 12, 2013 - 06:49 AM
well got it running about 5 minutes ago swapped distributors and it fired right up i guess the pickup in the distributor went bad. thanks guys for all the suggestions. anybody wanna buy a ford?
  • Craig., HDWildBill, chris m and 2 others have said thanks
#34 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 11,033 Thanks
  • 5,984 posts
Posted June 12, 2013 - 08:15 AM
Your ready for another 100K miles on that thing!!
#35 HDWildBill OFFLINE
  • 8,978 Thanks
Posted June 12, 2013 - 09:10 AM
Glad you got it running again.
#36 Alc ONLINE
  • 7,129 Thanks
  • 7,532 posts
Posted June 12, 2013 - 09:53 AM
Glad to hear she's going again :thumbs:
#37 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,026 Thanks
  • 3,172 posts
Posted June 14, 2013 - 01:49 AM
I just can't resist.
#38 boyscout862 OFFLINE
  • 13,442 Thanks
  • 9,391 posts
Posted June 14, 2013 - 09:28 AM
I have found that RockAuto is pretty good for cheap parts that have worked for me. They had a part for my 85 C10 that I had needed. It had been on a search with my local parts guys for 6 months. I saw an ad for RockAuto and tried them. It was in stock and cheaper than my local. I got the new pickup for my 85 C10 from them for $12. Since then I've gotten many clearance sale parts for my old vehicles. Good Luck, Rick
  • HDWildBill said thank you
#39 Cvans ONLINE
  • 7,102 Thanks
  • 6,299 posts
Posted June 14, 2013 - 03:13 PM
I wonder why they call a 5lb hammer a "Chevy wrench" ?
These electronic ignitions can be a real head scratcher when they start acting up. My 97 Ford v-6 kept fowling one plug every 1500 miles. If I ran ethanol in it things would be fine again. Figured it had to be the injector which I bought but never installed. Then after a year that cylinder wouldn't fire at all. Bad coil pack if that's what you call them. Replaced it and no more problems. The ethanol thing still has me baffled.
#40 Amigatec OFFLINE
Amigatec
  • 2,026 Thanks
  • 3,172 posts
Posted June 14, 2013 - 04:23 PM
I spent over 8 hours one day just to find out a 360 Ford wouldn't run on resister AC spark plugs.
#41 Cvans ONLINE
  • 7,102 Thanks
  • 6,299 posts
Posted June 14, 2013 - 08:16 PM
OUCH!!!!!! :mad2:
  • Amigatec said thank you
#42 CADplans OFFLINE
CADplans
  • 219 Thanks
  • 213 posts
Posted June 14, 2013 - 08:22 PM
Isn't AC a GM company!?  :ah_shoot:
I guess my Silverado would not run with Autolites!!  :oh_shucks:
#43 Amigatec OFFLINE
Amigatec
  • 2,026 Thanks
  • 3,172 posts
Posted June 15, 2013 - 04:31 AM
Yep that's true, he already had the plugs and wanted to use them. The next day I went down and bought some Autolites for it.
  • CADplans said thank you
